what Mirrors Will Fit A Mayfair - One Will Be Needed
16 replies to this topic
#1 adam_mini
adam_mini
  • 394 posts
Posted 20 February 2008 - 08:20 PM
Hi,
I have a 1987 Mini Mayfair which had grey standard mirrors on. When i got the car the drivers side had been bashed and the doors had been caved in which had smashed the drivers side mirror. I'm finding it really hard to get one so im wondering what other mirrors will fit. The drivers side has a new door skin on so it's not the problem, its the passenger side because it has been properly drilled with tapped pieces in which are like tapped out pieces of bar which the mirrors screw into. Because of this i am not sure which mirrors will fit into these holes. I've seen that rover mirrors are around £7 so i wondered whether it would be cheaper to buy a pair than just to buy one.
Also if anyone has a drivers side grey mayfair mirror i might be interested.
Any other mirrors going cheap maybe considered if they will definetly fit in the slots.
Any help greatly appreciated.
#2 sazal
sazal
  • 3,512 posts
  • Local Club: DCMOC
Posted 20 February 2008 - 08:31 PM
You had a look on ebay? The same happened to me :shifty: Also, you had a look on minispares, theyre selling off loads of rover mirrors, not too sure if they fit the holes though, sorry.
EDIT: found this one: wing mirror
Edited by sazal, 20 February 2008 - 08:32 PM.
#3 adam_mini
adam_mini
  • 394 posts
Posted 20 February 2008 - 08:48 PM
Hi,
Cheers for info,
I have seen a couple of mirrors on Ebay but they have gone for silly money.
I have had a look at MiniSports magazine and they had some silver ones which look good for £7 each but i don't want to buy them if they won't fit.
#4 adam_mini
adam_mini
  • 394 posts
Posted 21 February 2008 - 07:28 AM
Bump
#5 adam_mini
adam_mini
  • 394 posts
Posted 21 February 2008 - 05:58 PM
Come on someone has to know
Please :lol:
#6 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 21 February 2008 - 11:55 PM
It's hard to tell from your description whether the mounting you describe in your passenger door is standard. It should have a pair of Rivnuts squeezed into the door skin and the driver's door if genuine should have the same holes through the new skin. The actual rivnuts have to be installed after the skin has been fitted and so many people who aren't that experienced in fitting new skins to Mini doors overlook this part of the procedure. Can you post a picture of the mounting so we can see it and give advise?
#7 adam_mini
adam_mini
  • 394 posts
Posted 22 February 2008 - 04:47 PM
Hi,
Just been to have a look at the passenger door and i have taken some pictures of the holes that are there.
We used a pattern panel door skin on the drivers side because i needed to do the car as cheap as possible as it isn't going to be a show car just a cheap run around.
Hope these pictures help
Attached File  DSC02861.JPG   217.15K   1 downloads Attached File  DSC02860.JPG   243.34K   0 downloads Attached File  DSC02862.JPG   277.29K   2 downloads
Adam
#8 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 22 February 2008 - 05:06 PM
Yes those are standard mirror mountings. A standard type door mirror will be the cheapest and easiest option to fit there. For the driver's side all you need to to is measure and mark for similar holes of the same size and pop some Rivnuts into them.
As for building a cheap car by using pattern parts, it's rarely the case that the cheapest part makes for the cheapest repair. In my experience pattern body parts don't last as long as genuine ones so you may end up doing the same repair again sooner than you would like. Still, it's your car not mine so the choice is yours and it's done now anyway.
#9 james105
james105
  • 466 posts
Posted 22 February 2008 - 05:09 PM
Think i have a grey standard one knocking around when i stripped a mates car for my spares.
Will get back to you when i find out, as im about to leave for work, and im not going hunting in dirty boxes while where a suit n white shirt.haha
#10 adam_mini
adam_mini
  • 394 posts
Posted 22 February 2008 - 05:46 PM
Hi
Thanks for the information Dan.
Does that mean that any new rover mini mirror will fit or will it have to be an original?
May need the grey mirror James, it depends on whether another type will fit and how much you want for it, if you find it that is.
Adam
#11 1984mini25
1984mini25
  • 8,785 posts
Posted 22 February 2008 - 08:27 PM
I’ve got a spare good condition standard black plastic rover drivers side mirror going spare.
#12 adam_mini
adam_mini
  • 394 posts
Posted 22 February 2008 - 08:59 PM
Cheers but i either need a pair of silver or a pair of black plastic or just a grey drivers side mirror.
One mirror on its own unless its grey isnt really any good
Cheers anyway
Adam
#13 sazal
sazal
  • 3,512 posts
  • Local Club: DCMOC
Posted 22 February 2008 - 09:35 PM
Could spray them up to match your car?
#14 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 22 February 2008 - 11:58 PM
Not sure what you mean. Rover mirrors are original mirrors. Any Rover type plastic mirrors will fit, as will the late model optional plastichrome mirrors or any Tex or bullet mrrors if used with the commonly available adaptor base. There are also some bullet mirrors that fit these holes exactly without the adaptor.
#15 adam_mini
adam_mini
  • 394 posts
Posted 23 February 2008 - 04:39 PM
Hi, Thanks for the comments.
This isn't really an option as i dont have any of the paint that is the right colour.
What i meant by "Does that mean that any new rover mini mirror will fit or will it have to be an original?" is that will a modern rover mini mirror fit or will it have to be a part taken from an original car.
Well dont suppose it matters now as you have put nearly any mirror will fit so i shall probably put some silver colourcoded mirrors on from minisport.
Im quite new to minis so i'm not sure about all the bits like the mirror fixings for instance but i can always come on here if it get stuck.
Adam
