New Bmh Shell
Posted 21 February 2008 - 06:26 PM
Zeroasylum
Posted 21 February 2008 - 06:41 PM
Posted 21 February 2008 - 07:18 PM
Dont assume theyre ready to rub down and paint!
Theres little dings and wobbles and un-even panel gaps and very little seam sealer on them.
From what I remember, 2 of us spent a good day sorting out all these little niggles before they were good to re-prime and paint... Although you could just spot prime the little bits and just paint the shell in its production primer.
Quick edit... just thought, being a mini, might be a good idea to pop the seam covers off and paint these separate for more rustio protectio!
Edited by jack_marshall, 21 February 2008 - 07:20 PM.
Posted 21 February 2008 - 07:58 PM
Posted 21 February 2008 - 08:30 PM
I assume the shell will be primed underneath? if so, I'd rub it down with 320 paper, dusting etch over any bare metal areas. Then I'd apply a good rust preventative primer, and then the stonechip. Do a test on a scarp bit of metal to make sure the products work together, sometimes stonechip can have a bit of a "chemical beef" with some primers, and it could crack. If you apply the stonechip in several thin coats allowing each to dry, it should be fine. As for the rest of the shell, I'd use 500 on a DA, using red scotchbrite in any corners, hard to reach bits, then as above, apply etch primer to any areas you may have gone through, then it would be up to you whether you primed it or not before topcoat, It would be a good idea, especially on the outside, for corrosion protection.
What primer would you recommend and can I brush paint the underneath. i Assume it will come with the primer after the dip process. However would the dinitrol not be mor effective straight on top of that.
Zeroasylum
Posted 21 February 2008 - 08:40 PM
Posted 21 February 2008 - 09:29 PM
