hi i have just de-seemed my mini and i am ready to start to put some filler over it any tips, best way, prep, just that i hate using the stuff. thanks
Filler
*franky*
, Feb 25 2008 07:01 PM
8 replies to this topic
Posted 25 February 2008 - 07:01 PM
Posted 25 February 2008 - 07:11 PM
unlucky, there is a fair bit of fillering necessary to get a seamed mini to look right.
Posted 25 February 2008 - 07:14 PM
Make sure the surface you're putting filler on is free from rust/grease or any other contaminant, and is abraded. Never put filler over shiny anything, or it will fall off. ideally you shouldn't put filler over paint, so bare metal the area you wish to fill over. Rub it down starting with 80 grit, go down to 120 or 180, then finish in 180 or 240. 240 is better if you're not using a high build primer. Use a bulk filler like Upol Fantastic or if you're on a budget, EasyOne or EasySand. For the last skim of filler use polyester stopper, to fill in any pinholes or imperfections. Upol Topstop Gold is fine. Then prime as usual.
Posted 25 February 2008 - 07:46 PM
the car has been shot blasted will i still have to rub it down or not?
Posted 25 February 2008 - 08:05 PM
Is it just bare blasted metal? if so it'll stick to that brilliantly.
Posted 25 February 2008 - 08:10 PM
just a light primer mate will a have to rub that off?
Posted 25 February 2008 - 08:15 PM
I'd give it a rub with 80 grit, just to be on the safe side, can't really say without seeing it.
Posted 25 February 2008 - 08:17 PM
thanks peter.
Posted 25 February 2008 - 08:38 PM
No worries mate!
