Complete Respray
Posted 26 February 2008 - 12:30 PM
I am thinking of giving my mini a complete bare metal respray but being a novice i need some help
So if was wanted to give it a good 3 or 4 coats, all in same clour, how much paint would i need to buy?
I will be using a compressor and spray gun, not rattle cans, and it will be a normal colour, no special candy flips or anything.
Any guidance would be greatfully recv !
J
Posted 26 February 2008 - 01:11 PM
I think its 3 liters, Dont forget primer and thinners!
Edited by matty135790, 26 February 2008 - 01:12 PM.
Posted 26 February 2008 - 04:25 PM
Posted 26 February 2008 - 04:35 PM
Posted 26 February 2008 - 05:22 PM
Im not sure how much you'll need if your using cellulose.
I doubt you can get hold of normal 2k anymore, as its banned.
But if your using high solids 2k then you will need about 3.5 litres, to do inside, outside, engine bay, boot.
Posted 26 February 2008 - 06:30 PM
Posted 27 February 2008 - 06:49 PM
We used Lechlar MAC 5 and that specifies 2 - 3 coats only..
At the time Panelbeaterpete was a great source of info and he recommended 3 for that spec of paint.
Posted 27 February 2008 - 07:21 PM
Anymore useful tip before i start ?
Posted 27 February 2008 - 09:03 PM
also you need to use etch primer on any bare metal before spraying any other primer on.
do some practise runs with the gun, the ratio of thinners to paint may need altering depending on the weather conditions..
Posted 27 February 2008 - 09:16 PM
Posted 28 February 2008 - 06:52 PM
biggest tip is make sure you prep the car right in the first place, I'm a novice as well and can tell you once you get a shine any dents or blemishes in the bodywork you've missed will standout.
This is all great info, cheers
So have you done yours now then ?
Got any pics / is it listed in the projects section ?
Posted 01 March 2008 - 10:24 AM
We are actually tempted to do it again, weather went a bit cold to get the best of shines, but bit of polish on it it comes up ok
This is a link from start to finish
http://www.orrp.com/...p?topic=34555.0
