No need to apologise, it's what the forum is here for! Agreed jenolite is excellent stuff, but you should try and remove as much rust as possible prior to treatment. A wire brush isn't the best way really, bare metal the area, and if you've not got access to air tools the best way is 80 grit sandpaper, get it right into the seams as much as possible, and remove as much rust as you can. Treat whatever is remaining with Jenolite. After the 80 grit, flat the area with 180, then 240 then 500, and etch prime, then prime. Flat the primer with 800 wet&dry, trying to keep the abraded area as small as possible. clean up the paint around the area with G3, this is so you don't topcoat over dirty paint, which makes losing a blend more difficult. Scotch brite about 2 inches around the area, and mask off around it, making a flap edge with the tape, basically you fold quarter of the width of the tape against the sticky side of itself, and apply it around the area. This creates a softer edge to paint to, as the paint creeps under it so as not to create a hard line. Saying that, you shouldn't go up to the tape with the paint anyway, but if you do it makes it easier to make an unnoticeable blend. Apply colour to the area up to where you abraded with the 800 paper, and then lacquer to the edge of the scotched area. If you're using a solid colour which requires no lacquer, put the paint right to the edge of the scotched area. When it's dry, rub the edge of the lacquer slightly with G3, to smooth it out and blend it in with the existing paintwork. This is made easier if you have an electric buffer, it is possible by hand but not ideal.
Unfortunately once rust has started there is virtually no way of getting rid of it permanently, it'll come back soon, but how soon depends much on how well you repair it and whether it's kept outside, driven in the rain etc etc. The seams on the front panel are especially difficult to fix, as the rust starts right in the seam and creeps out, therefore by the time you can see it, it's well established.
Edited by panelbeaterpeter, 27 February 2008 - 09:14 PM.
