Please
Posted 29 February 2008 - 10:12 PM
Posted 29 February 2008 - 10:17 PM
Posted 29 February 2008 - 10:20 PM
Posted 29 February 2008 - 10:23 PM
Posted 29 February 2008 - 10:35 PM
Edited by minimender, 29 February 2008 - 10:37 PM.
Posted 29 February 2008 - 10:58 PM
Posted 29 February 2008 - 11:03 PM
Your right....my eyes arn't what they were.Those pliers are just a small pipe bender for forming hard brake lines to shape. hasn't got a powered pump is £678.00
Posted 29 February 2008 - 11:12 PM
Posted 29 February 2008 - 11:19 PM
Posted 29 February 2008 - 11:24 PM
If you want the best of the best aerospace quality go for Aeroquip
http://www.aeroquip....C001-E-p5-8.pdf
All you need to cut the hose and fit end connections is:
Masking tape
Hacksaw
x2 adjustable spanners
Just be sure to follow aeroquips guide to the letter when it comes to insertion length of the hose into the end fitting and never be tempted to overtighten.
If you happen to know anyone in the aircraft industry / air force, ask them to blag you some as they use miles of the stuff.
Posted 29 February 2008 - 11:25 PM
Posted 29 February 2008 - 11:27 PM
Point taken..thanksThe above aeroquip link (for fuel, lube, coolant and air usage, read the text) shows that the maximum operating pressure is only 1000psi, braking systems are somewhere between 3000 and 5000 psi, if you value your life and that of others buy some already made up, much cheaper than the consequences of an accident caused by having no brakes when you need them most.
Posted 29 February 2008 - 11:29 PM
Posted 29 February 2008 - 11:33 PM
Good advice and well worth rememberingMost manufactured brake lines are tested to at least 10,000 PSi and good quality ones are rated for 12,000.
Posted 29 February 2008 - 11:41 PM
Edited by Dan, 01 March 2008 - 12:06 AM.
