Oven Baking
Posted 02 March 2008 - 10:47 AM
I painted my rocker cover last night. It's been in the garage all night (cold) and the paint is just about dry, but at the bottom it really isn't hard enough.
Is it ok to put it in a fan oven for a bit?
If so, what temp and how long?
If this is a good idea. When I do the top of the rocker cover. How long should I leave it to dry before putting it in the oven?
Thanks,
Ed.
Posted 02 March 2008 - 10:49 AM
Posted 02 March 2008 - 10:55 AM
Posted 02 March 2008 - 11:04 AM
Not sure about the herbs, I think an oil filler cap on the top would make it tastier.
When I'm painting the other side, do you think it's a good idea to heat up to 50-60c before painting?
And then do the same, leave overnight, then 30mins in oven?
Then garnish with some fresh herbs and and serve with a multigrade and shallot sauce.
Personnaly i would only paint the outside of it due to heat and oil contamination, when the engine is run up to heat it may flake. I would strip the inside back to metal as it was. But yes okay to bake in oven very low bake or if you have a fan heater sit it about 3 foot away in a corner aaiming at the cover this always works for me
Posted 02 March 2008 - 11:29 AM
Hmm that's a bit annoying. It was originally painted on the inside, but I see your point.
I think I'll leave it as it is for the moment and perhaps strip it in a few weeks. I've really had enough of paint stripping this week!
Posted 02 March 2008 - 11:33 AM
Paint feels really tough.
I'm ready to do the other side now!
Posted 02 March 2008 - 01:44 PM
Posted 02 March 2008 - 02:11 PM
is that a alloy cover? did you etch first and what type of paint did you use?
I used zinc primer and painted it with something that halfords mixed up for me (not sure what type of paint it it), thinned 60% with cellulose thinners.
Posted 02 March 2008 - 04:41 PM
Posted 02 March 2008 - 05:05 PM
You really must remove the paint it will react with the hot oil and the fact that you didn't use an etch primer for alloy it will peel off for sure
Ok thanks, I'll make sure to remove it on the inside.
Can you recommend any alloy etch primers (and a link to a site that sells them)? I want to restore some alloy wheels soon so it would def be good to get the right stuff on future refurbs.
Thanks,
Ed.
Posted 04 March 2008 - 05:06 PM
body shops are useing it quite allot now.
Posted 04 March 2008 - 05:49 PM
Posted 04 March 2008 - 06:08 PM
And by the way, alot of/ most paint products are manufactured by U-POL, for other brands.
