I Messed Up
Posted 03 March 2008 - 01:47 PM
Posted 03 March 2008 - 02:09 PM
Posted 03 March 2008 - 03:41 PM
Posted 03 March 2008 - 04:00 PM
Posted 03 March 2008 - 04:01 PM
as said above leave it for a while then try doing it
i've made the same mistake many times and also made the mistake of sanding back straight away and trust me it doesnt work!
Posted 03 March 2008 - 04:31 PM
Posted 03 March 2008 - 04:55 PM
dont worry tho, these things can be fixed!
Posted 03 March 2008 - 11:09 PM
can you post a pic? cant really advise with out seeing it.
I hope you're right.
Posted 04 March 2008 - 09:38 AM
If you found filler when you rubbed it back, then it's probably where someone has previously skimmed over some bubbles and is now more rusty underneath.... if you don't get all the filler off and start again while it's small you might be looking at a new A-Panel in the near future!
As for the paint, did you use a clear lacquer over the top? As that paint will never look right unless you do it.... Wash the car in a few days time, then cut it back using a cutting compund until it looks and feels smooth when wet. Make sure there's NO dirt and dust anywhere near where you're spraying, cover the wheel with a sheet and mask up the rubber bits..... then dust over the area with your top lacquer......
Good luck with it!
Posted 04 March 2008 - 09:45 AM
What were you doing spraying bits of your car without washing first?? All the dust particles will have shot off and landed in your new paint!
I washed the parts of the car before I sprayed them, I'm not that stupid.
I rubbed the filler down and there was good metal underneigh, no rust to be found.
Two coats of lacquer were used, the finish and shine is fine. It's just a rubbish colour in the light, maybe I didn't use enough coats.
Posted 04 March 2008 - 09:48 AM
If you think spraying that close to dirty panels is sensible then I will cease to give you anymore advice on the subject........
Posted 04 March 2008 - 09:55 AM
Is it a problem spraying near dirty panels then? I would have thought that it would only affect the parts that you're actually spraying.
Edited by Mini_Magic, 04 March 2008 - 09:56 AM.
Posted 04 March 2008 - 10:03 AM
Imagine how much air pressure there is to get the paint out of the can/spray gun? That's moving all the air around the bits you're spraying and subsequently all the dust particles. They'll land on sticky paint and make a nice bumpy finish for you!
Small areas like that aren't quite as important, but I bet you ended up spraying very close to the dirty bits didn't you?
Anyway, back to the problem in hand..... as others have already said, try cutting it back before you start over. I'd use wet cutting compound first, but that's just my preference!
Posted 04 March 2008 - 10:08 AM
Such as wet and dry paper?
I feel it would be best to cut back as much as possible back to the original paint, it was only a small area on the A panel which actually needed spraying.
As I said before, I messed up.
Posted 04 March 2008 - 10:14 AM
No, cutting compound is a paste, which you use with water..... you can buy it from Halfords or any other Auto shop. I prefer it (to paper) for small areas like that as you can blend into the original paint without rubbing through the old surface too!
Just been looking at the original pic though. I Wonder what colour the base coat was for that paint, as it looks like you haven't got enough blue on there and it's a little bit pale.... maybe cut back the lacquer, add a couple more light layers of blue then try the top coat again??
It's notoriously hard to match a pearlescent paint though We'll be doing it very soon in exactly the same colour on our VTEC mini......
