Whats the difference between having a new inner and outer sill on the mini..in comparison to the door step?
Is the door step the step that fixes the outer sill to the inner sill?
I need some pics of my mini on here..im going to take some tomo and then you will all beable to tell me whats what..lol
cheers
Whats The Difference?
abersurfer
, Mar 03 2008 06:29 PM
5 replies to this topic
Posted 03 March 2008 - 06:29 PM
Posted 03 March 2008 - 06:34 PM
outer sill is on the outside from the seem down
inner sill is from in the inside from the floor up
door step is the bit under the door between the inner and outer sill
Posted 03 March 2008 - 06:36 PM
Thanks bungle..
..so when replacing the inner and outer sill..they both connect to the door step?
Posted 03 March 2008 - 06:40 PM
Yup, the inner sill spot welds to the door step where the rubber door seal goes on.
Outer sill spot welds to the door step along the edge that runs along the side of the car.
If the door step is solid, it is possible to split the inner and outer sills and keep the door step inplace.
Posted 03 March 2008 - 06:44 PM
ahhh nice one...with the door step..it has ony rusted through slightly through on one area...is it possible after doing the inner and outer sill to just replace a small section or weld on a small plate?
Would this work?
Would this work?
Posted 04 March 2008 - 04:34 PM
Yes this would work take the outer sill off and then you can repair the door step from the underside ie. a plate from underneath paint it all for added protectionahhh nice one...with the door step..it has ony rusted through slightly through on one area...is it possible after doing the inner and outer sill to just replace a small section or weld on a small plate?
Would this work?
then you can let a piece of metal in from the face on top of the plate underneath. Hope this makes sence
