Steering Wheel Nut Size?
Posted 04 March 2008 - 11:41 PM
Posted 04 March 2008 - 11:59 PM
on my 1994 sprite the size scoket i used was a 30mm which i got from B&Q for about 4.50 which is a 1/2 inch drivehi, tryed searching but it was for the wrong year, lam trying to take the centre nut off my 1989 mini steering wheel and l have not got a socket which will fit, have any of you nice boys and girls got an idea, and where to buy from, many thanks,this is such a helpful forum,
hope this helps
Posted 05 March 2008 - 12:00 AM
I bet it's an inch 'n five sixteenths, everything else is. Measure it across the flats.
Posted 05 March 2008 - 12:30 AM
hi, is this the same size as a 30mm, if not where can l get a 1.5/16 from, thanks for your helphi, tryed searching but it was for the wrong year, lam trying to take the centre nut off my 1989 mini steering wheel and l have not got a socket which will fit, have any of you nice boys and girls got an idea, and where to buy from, many thanks,this is such a helpful forum,
Posted 05 March 2008 - 12:35 AM
Posted 05 March 2008 - 12:41 AM
Posted 05 March 2008 - 01:07 AM
I'm sure 1"5/16 is 34 mm
Yep - roughly
1" = 25.4mm
1/16" = 1.59mm
so 33.34mm
I'm pretty sure it's the same size as the crank pulley too as I have a howge ring spanner I've used on both.
Posted 05 March 2008 - 08:57 AM
David
Posted 05 March 2008 - 09:10 AM
No it wasn't, I think that's the right size for an MPi though. You can get away with a 34mm but it will damage the nut and it is not a good idea to use this size if you are fitting a new aftermarket wheel with a seperate alloy hub. These usually need to be pressed on using the nut because they are a much tighter fit than the original wheel and using the wrong size socket to do that will cause much damage, mainly to your knuckles every time it slips off. 1 5/16th sockets aren't rare but you'll have to go to a proper automotive supplier to get one, Halfords don't have them. All the Mini specialists do.
Posted 05 March 2008 - 04:42 PM
thought i was cracking up!!!! double checked the size on the socket it is 30mm thought thier my be differant sizes on other minis thats why i put it was a 1994 mini sprite mind you mine is a spi.on my 1994 sprite the size scoket i used was a 30mm
Posted 05 March 2008 - 05:26 PM
The other possibility is that someone has swapped the column for the later airbag type.
Posted 05 March 2008 - 05:38 PM
thanks for that dan i will try a get a larger nut i would never have known if this question hadnt been asked just goes to show what a good forum this isHow strange! What is most likely is that someone has lost or damaged the original nut in the past and substituted what would be a standard nut for that size thread. The steering wheel nut has a large flange intentionally, it's because of the need to press the wheel onto the taper when fitting it. A thin nut would be put under a lot of load doing that. It also makes for a good large area of contact with the hub and lockwasher to keep the fitting secure. You should get the proper nut on there really.
Posted 05 March 2008 - 07:10 PM
Posted 05 March 2008 - 07:27 PM
it had the original steering wheel on it when i got it in fact the whole car was unmolested the steering wheel nut still had a plastic nut cover over it it , it had no lockwasher all very strange dont you think? so it my be possible it has a later columnACH6001 is the nut and 53K3480 is the lockwasher. Are you certain it doesn't have the later column as this nut won't fit if it does. Is the steering wheel original? It may be that the nut's been swapped because of clearance issues in the hub if it's aftermarket.
Posted 05 March 2008 - 07:30 PM
