Mines a bit lumpy at idle, don't trust the tacho in the car... mines way out! Had a garage do the timing and idle, he set it at 750rpm while the tacho was reading nearer 500rpm. I don't think anything is wrong with the engine, it smooths out at about 1000rpm (according to the tach
) so more like 1250rpm lol
How did your garage know the engine was doing 750rpm? You tacho works in a way that it is extremely unlikely for it to be wrong. The only way it would be out was if it is the wrong tacho for the engine, ie it's designed for a 6 cylinder engine, not a 4.
My tacho is one taken from a mini, a genuine one. The garage was using a snap-on laser gun to do timing, linked to the 1st HT lead. it displays both the timing degrees and the RPM speed. This is HIGHLY unlikely to be wrong, as the timing would then be out as well, as I said engine runs fine at 8 degrees. It's the tacho that's wrong.
