Vented And Non-vented Disks
Posted 14 March 2008 - 09:11 PM
I have a problem with my brakes. I have the metro 4 pot calipers on my car. The car had solid disks on it when i got it. I am trying to replace the disks and pads. I would like to put vented disks on my mini but im not sure if they will fit without any further modification. Also when looking on Mini Spares i see a Disk set with pads (MS39). The pads are look exactly like what came off of my car. Will the Vented rotors fit on my mini? Im going to get some pics on to help anyone out who my help me with the info i need.
Posted 14 March 2008 - 09:22 PM
Posted 14 March 2008 - 09:23 PM
Posted 14 March 2008 - 09:24 PM
Hello all,
vented discs won't fit onto non vented calipers, although there is a kit which includes a set of spacers which go between the two calipers halves. this will enable you to fit vented discs....
Posted 14 March 2008 - 09:26 PM
Posted 14 March 2008 - 09:36 PM
So based on the pics of what i have all i would need is the spacer kit for the calipers? would i need a different set of drive flanges?
you will need a set of vented discs, caliper spacers and i think you will also be in need of a new set of pistons....(they look full of rust :S)
not sure about the drive flanges though....but i think they are different....
this is the link for the spacers if you like http://www.minispare....aspx?pid=42224
Posted 14 March 2008 - 09:40 PM
Posted 14 March 2008 - 09:46 PM
Thanks for all the help. So is what was on the car wrong? ie wrong disks for those calipers
no....everything seems fine....you must know that naturally aspirated(non turbo) metros were fitted with solid discs and turbo ones had vented dics....they had two different calipers....one with spacers and one without....yours are the ones which were fitted to non turbo metros.....
another thing....have you tried removing those pistons???
Posted 14 March 2008 - 09:48 PM
Posted 14 March 2008 - 09:53 PM
well minispares has basicaly everything you'll need, but i found these pistons really impressive...Ok thanks. No i have not tried to remove them yet but i am planning on trying to find rebuild kits for them. any ideas on where to get kits?
link
quite expensive for onyl a set of pistons but must say they are extremely lightweight and more durable than stainless steel
Posted 14 March 2008 - 09:56 PM
Posted 14 March 2008 - 09:58 PM
Posted 14 March 2008 - 10:05 PM
Posted 14 March 2008 - 10:07 PM
Edited by romblu89, 14 March 2008 - 10:07 PM.
Posted 14 March 2008 - 10:11 PM
they also have wheel locating lugs on them
heres a pic
Edited by Doodle, 14 March 2008 - 10:14 PM.
