Blow Over Respray
Posted 15 March 2008 - 03:25 PM
Posted 15 March 2008 - 04:38 PM
Posted 15 March 2008 - 05:15 PM
Posted 15 March 2008 - 05:25 PM
Posted 16 March 2008 - 11:23 AM
Posted 16 March 2008 - 02:18 PM
If your going to have it sprayed... use primer.. Plus if your get the high build primer and rub it down.. its a gorgeous finish even in matt primer...
Posted 08 May 2008 - 11:04 PM
Posted 09 May 2008 - 11:36 AM
depending what primer you are using (a question that SHOULD HAVE BEEN ASKED) can react with whats under it, celly primer tends to react more than 2k primer.
a waste of time and money to reprime.
this is my opinion and will differ from others.
Posted 09 May 2008 - 05:27 PM
If your gunna use celly u can buy a twin filiment organic vapour mask which is more than adequate for the the task is your car a base colour e.g. red with no metalic?
Also I would recoment taking a bit of advice from Panelbeaterpete as he is a "PAINT DOCTOR" plus i have always used primer to get a bettter finish plus all the area is then prept ready for a trace coat to see any inperfections.
"Midridge2" made no sence fella kinda contradicting your self primer is paint and you would key the original paint in order for the primer to etch its self to the original paint. So how come the primer wont etch?
Kind regards
Brad
My opinion is just that, just replying to others resonces please dont take offence "Midridge2"
Posted 09 May 2008 - 05:51 PM
Posted 13 May 2008 - 11:59 AM
Posted 13 May 2008 - 04:53 PM
if the original paint is rubbed down correctly then paint/primer will stick, if its not rubbed down correctly and you put primer on then you put paint over the primer the paint and primer will come off.
so just because you put primer on first it does not gaurentee that the paint/primer will not come off. did you understand that better?
just out of interest pete maybe the paint doctor because he has worked for just a few years in a paint shop but i have worked in a bodyshop for 35+ years.
Posted 13 May 2008 - 05:06 PM
Posted 17 May 2008 - 11:15 AM
if it is flatted first and properly degreased (especially if there may be any silicon present) the paint will not come off ( especially if its 2 pack).
Posted 17 May 2008 - 09:14 PM
