How Much Is This Topic Worth?
10076 replies to this topic
#3031 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,145 posts
  • Name: Sean
Posted 20 April 2008 - 12:22 PM
Just tried my code, I can get the 151 for £211!!!
#3032 GreaseMonkey
GreaseMonkey
    Has Ratchet, Will Make Noises
  • 3,663 posts
Wow im flattered at that offer Shifty
but i already got a code through email from them as well, they are having a vat free day on sunday i think so i should be going down there.
I think ill get the 151te instead of the 160, the 151te is more than enough
#3033 Shifty
Shifty
  • 13,145 posts
  • Name: Sean
Posted 20 April 2008 - 12:27 PM
If you can afford the 160, then i'd get that.
It looks a nice welder, the duty cycle is longer as well, so you will be able do more welding in 1 hit.
I've just checked and it takes 5kg reels as well.
There are adaptors available to convert the reel sizes
For hobby use 5kg is usually best as if the reels are left standing they rust, and welding wire "goes off" after 12 months as well.
BUY IT!!
#3034 Racer_Pete
Racer_Pete
  • 2,492 posts
Anyway im off, Trying to get laid
JOKING!!!
seeya.
#3035 GreaseMonkey
GreaseMonkey
  • 3,663 posts
Posted 20 April 2008 - 12:30 PM
Yeah they 160 should be mega affordable on the vat free day :(
Ill be running it off 13 amp as well but ive heard everywhere that its fine, even on the mig welding forum they say its a okay
i think it may be the 160 then :(
a plus is that it comes with the big boy regulator and a thing on the back already for a big bottle as well :)
#3036 GreaseMonkey
GreaseMonkey
  • 3,663 posts
Posted 20 April 2008 - 12:35 PM
or should i stick with a 135te ?
and spend 30 quid converting it to big bottle use after a while ?
i could have my first mig project making a cart for the 135te
arghhhh the choices the choices :(
#3037 GreaseMonkey
GreaseMonkey
  • 3,663 posts
no no stick with the 160 monkey man
#3038 Shifty
Shifty
  • 13,145 posts
  • Name: Sean
Posted 20 April 2008 - 12:41 PM
See you in abit Petey.
I run my welder off an extension lead from a 13amp supply, very naughty!!
It is ok because i don't usually weld up big stuff at home
This is my Beast
Before this I had a cemont which i never got on with
My 1st welder which I got when I 15 was a maypole mig turbo 160, ahh memories
At work we've got an old SIP 170, SIPs get some bad press but this one has been a good welder.
I have always used it off a 13amp supply and have welded up many frame, bits and bobs with it. Its done up to 10mm thick mild steel with some good results.
The thermal overload in the SIP trips before the factory wiring melts!!
#3039 GreaseMonkey
GreaseMonkey
  • 3,663 posts
Posted 20 April 2008 - 12:47 PM
ahh then i should be fine with the 160, better than getting a 135te or 151 because at least i know i have more oomph when i need it for other things :( and its more cost effective with already having the reg and thing to hold the bottle
and it looks a beast
Edited by GreaseMonkey, 20 April 2008 - 12:48 PM.
#3040 Shifty
Shifty
  • 13,145 posts
  • Name: Sean
Posted 20 April 2008 - 12:50 PM
Yup, go with the 160, you can't beat oooompff
Use the bigger bottle, will work out cheaper in the long run.
Get it bought, then post up some pics of your welding, won't laff, honest!!
Its a shame you're so far away, I'd pop round and get you started!!
#3041 GreaseMonkey
GreaseMonkey
  • 3,663 posts
Posted 20 April 2008 - 12:53 PM
im sure a nice road trip from shropshire to London would be awesome :(
having someone help start me off would be awesome :(
#3042 Shifty
Shifty
  • 13,145 posts
  • Name: Sean
Posted 20 April 2008 - 01:03 PM
You're more than welcome to pop up to Shropshire?
Why not come up with Pete for the thong run?
#3043 v8mini
v8mini
  • 726 posts
  • Local Club: Minis on the run
Posted 20 April 2008 - 01:04 PM
Should I waste my money on these?
going by the description they are a must have..
Stainless steel manifold studs, aircraft spec nuts and washers-looks great
#3044 Shifty
Shifty
  • 13,145 posts
  • Name: Sean
Posted 20 April 2008 - 01:07 PM
Hey there V8 how are you, They are nice studs as well!!
#3045 GreaseMonkey
GreaseMonkey
  • 3,663 posts
as much as i would love to
i cant :(
busy man :(
6 user(s) are reading this topic
0 members, 6 guests, 0 anonymous users
