ok just a quick query to make sure i havent made a stupid mistake
i applied the seam sealer to the rear passenger arch area once everything was primed and nicely dried, then gave the seam sealer 15 minutes then applied the stone chip
now im a little worried, will the seam sealer set ok around the stone chip? i didnt heavily cover the seam sealer with stone chip as i didnt want to have it stay like putty
Stone Chip On Seam Sealer?
lewis
, Mar 18 2008 10:45 PM
3 replies to this topic
Posted 18 March 2008 - 10:45 PM
Posted 18 March 2008 - 10:52 PM
Ideally you should have given the seam sealer a good 2 hours to set properly. I dont know if it will react or not now tho, ive never made the mistake!
Posted 18 March 2008 - 11:33 PM
its ok ive rectified it now, the stonechip has set so ive carefully skimmed a thin layer of the seam sealer off
i will keep a good eye on it though as i dont want a horrible reaction and have to grind the panel back to bare metal again
thanks for the info
thanks for the info
Posted 19 March 2008 - 05:06 PM
right seam sealer has set nicely, will give it another day then il put a second layer of stonechip then the layers of paint
lovely jubbly!
lovely jubbly!
