Petrol
Posted 26 March 2008 - 10:54 PM
any help would be grateful
thanks simon
Posted 26 March 2008 - 10:58 PM
If you are used to a "normal" car then the Minis fuel tank is rather small, 7.5 gallons to be exact.
Posted 26 March 2008 - 11:41 PM
Think thats bad, the mokes 5.5 Gallons!You don't say how much mileage you do in that time.
Posted 27 March 2008 - 02:35 PM
i do very little mileage 30miles at the most, and its only around town,
Posted 27 March 2008 - 05:52 PM
has it been serviced in a while?
also take the plugs out and see what colour they are?
Posted 27 March 2008 - 05:58 PM
hi filled my tanks not so long ago and done a 120miles and there was still 1/4 of a tank left. check for fuel leaks and see if your fuel is adjusted right.gees thats quite bad!
Posted 27 March 2008 - 06:11 PM
On the tip of the spark plugs, white indicates a weak mixture, if black and sooty its too rich.
It should be light tan/grey-brown color
Hope this helps!
Posted 27 March 2008 - 07:49 PM
the fuel pump seal may have gone and be leaking into the oil.......big bang on the cards if it is! so make sure
id jack the car up and check for leaks too, more than likely leaky than seal!
better to be sure though!
Posted 27 March 2008 - 09:31 PM
As mentioned, check the colour of the spark plugs. When they are a greyish brown (tea biscuit colour), the mixture setting is correct. If the fuel consumtion is still high, check for leaks all along the fuel lines, and also the fuel tank.
With the plu colour correct, such eccessive fuel consumption can only mean the fuel delivery system is leaking
Posted 28 March 2008 - 09:49 AM
thanks simon
Posted 28 March 2008 - 09:56 AM
Posted 28 March 2008 - 11:35 AM
That equates to about 7.5 miles to the gallon, i think you must have a leak or someone is syphoning your tank, if it was running that rich to do 7.5 miles to a gallon.. well it wouldn't run... even on my turbo being driven excessivly hard i could get about 10 miles to the gallon
Posted 28 March 2008 - 11:51 AM
3 of the spark plugs a brown ish colour, and are slighty sooty,
however 1 spark plug was very bad, very sooty and black, this came out of cylinder 2, in comparison it was extremely bad compare to the others,
additionaly i checked the oil and it doesnt smell of petrol, and i cant find any leaks, currently
and i do believe it could with a new air filter, the one on isnt bad but its not great and for a couple of quid, a new might make all the difference.
its clear i need a new set of plugs but these plugs havent been in long, so does any one have any ideas?
thanks simon
Posted 28 March 2008 - 11:53 AM
could be the head gasket
Posted 28 March 2008 - 12:06 PM
is it oily to touch?
do you mean the spark plug, if so, no, its just very sooty, and a lot worse than all the others, its strange as the car runs fine and after its warmed up, it runs nearly perfectly, its just so poor on fuel. i know the gauge isnt fully acurate, but i can see how much i have used.
do you think engine could be on the way out?
