Indicator Problems
Posted 28 March 2008 - 02:26 PM
Posted 28 March 2008 - 02:31 PM
Posted 28 March 2008 - 02:32 PM
Turned out to be a bad earth on front indicator.
Remove the lens and prod/firk the bulb, chances are it will work!!
Clean up the contacts on the bulb as well as the earth and that should sort it
Seamus
Mine used to do it when I had a bad earth on the rear light clusters, it also did it when the front indicator connections lost their insulation and shorted on the bodywork.
oooh i see, what do I need to look for exactually? haha, Im actually terrible @ electrics.
Posted 28 March 2008 - 02:33 PM
I had exactly the same prob with my mini.
Seamus
hmmm, its a brand new bulb
Posted 28 March 2008 - 02:34 PM
Posted 28 March 2008 - 02:38 PM
Seamus
hmmm, its a brand new bulbI put it in like 10 mins ago.
Have a look at the socket where you put the bulb into, chances are its got a covering of green power on it, give the contacts a clean with some fine sandpaper and try again!!
Seamus
Posted 28 March 2008 - 02:40 PM
Posted 28 March 2008 - 02:41 PM
I cleaned up the mounts on the rear cluster because thats how it earthed, I have the plastic type front indicators so I have no idea how that is earthed.
Cluster meaning like the housing for the indicator? ive got a clubman, how do I remove it for a clean up.
Posted 28 March 2008 - 02:44 PM
Posted 28 March 2008 - 03:11 PM
Posted 28 March 2008 - 03:44 PM
If your hazards work and flash fine, but your indicator stays on and doesn't flash, then the problem is almost certainly your indicator flasher unit. There are separate flasher units for hazards and indicators, one from a permanent live for the hazards, the other from a switched live (usually) for the indicators. Find and swap the flasher units over to test, but if that works get a new one for the indicators circuit.
Posted 28 March 2008 - 05:35 PM
Sorry - only just saw this.
yea my friend told me, so the flasher unit is exactually the same for the hazards? blimey, I aint got a clue where its gonna be, Ill order myself a new flasher unit :] tar everyone for help!
Posted 28 March 2008 - 07:52 PM
Have you tried your indicators when your engine has been running too? Sometimes a poor connection can cause them to run slowly or not at all when the engine is off.
I recently replaced the fuse box on my Mini and that made a hell of a difference as my old one was rusty as hell on the back. Now my indicators work perfectly again.
Posted 29 March 2008 - 10:13 AM
The indicator flasher unit will be tucked up behind your dash clocks. You can reach it by putting your hand up and under the parcel shelf and feeling for it.
yea I run it for a little bit & noticed that on the clock indicators it started flashing, but none of the exterior indicators are working, Im going to halfords later to pic up a new unit! :] hopefull it does the job!
