Hello,
I need some halogen lights to go with some spots I have just got which are halogen. My headlights will look very dim otherwise!
I have had a look around and nothing has stood out yet. I like the bowl shape of the standard lights but this does'nt seem to come across in the Angel Eyes which is a shame. A couple of friends have p700's I think they are called but they wouldnt suit my car as they look to 'classic'
To sum up, I want a pair of halogen headlamps, which still have the bowled shape like the standard lamps, any ideas? many thanks
TML
Halogen Lights
themanlegend
, May 02 2005 10:15 AM
7 replies to this topic
Posted 02 May 2005 - 10:15 AM
Posted 02 May 2005 - 04:15 PM
you can get halogen std lights and even xenons now! or if they are dull yuo could always use some brighter bulbs but these will b illegal for road use after a cirtain year
Posted 02 May 2005 - 09:09 PM
xenons!? Cool.. where where, how much??
Posted 04 May 2005 - 04:34 PM
thanks
Posted 11 May 2005 - 04:20 PM
get some wipac halogen lights, these are what are fitted to the mpi minis, then get some xenon bulbs, I got mine off ebay from hongkong, they are rated at 55/60w but are the equilivant od 110/130w, hehe means night time driving is much better.
Posted 11 May 2005 - 04:33 PM
I think WIPAC are the only one with the curved glass like the original sealed beams, the cheaper ones have flat fronted glass and do look a bit strange...
also, to prevent rusting of the silvering spray the back of them with heat resistant paint before you fit them...
I just had to replace a set of my WIPACs and at 40 quid a throw thery're not cheap.
Oooh.. ps if you fancy splashing out a few hundred, you can also get H4 HID conversions... talk about bright !!!
eg.. clicky link
eg.. clicky link
Edited by GuessWorks, 11 May 2005 - 04:37 PM.
Posted 12 May 2005 - 09:33 AM
the HID conversion arent worth it yet, they are still way over the odds, if you fit the xenon bulbs like i have they are the same, they have the same look, the same different colours (ie bright white - to - blue depending on what colour rating you get) they have the same gas in them as the HID lights, the only differenace is that that have a filimant where as HID have 2 contacts and they arc through the gas to create the light.
Karl (whos done his home work )
