I have fitted a KAD triggerwheel and sensor bracket, sen8d sensor as provided, an edis 4 unit and coil pack and custom plug leads.
i have tried 3 different layouts of the wiring for the coil and edis unit which were found on various sources, i'v altered the bracket so it gets close enough, i'v reversed the polarity of the VR sensor, checked the clearance of the sensor with proper slip gauges, checked the resistance of the plug leads (which are new anyway) and i am still at a loss
when the ignition is at position 2 i get:
+12.48v to the centre pin of the coil pack
+0v on the outer 2 pins on coil pack
+1.5v to both sides of the VR sensor
+12.48v on the PIP
+12.48v to pin 8 on edis (live in)
i have had the plugs out of the engine, earthed and a timing light attatched to them individually and i STILL cannot get a spark, i'v searched through the megajolt guide in FAQ and found nothing to help, i'v also searched the forum and found nothing that i haven't already done.
if someone knows a way of testing the edis unit and/or the coil pack without the car running that would be a great help, other than that i am looking for suggestions as to why i cannot get a spark
if any other information is required for help to be given it will provided ASAP
