Clear Coat
Posted 03 April 2008 - 03:05 PM
should i wet and dry before clear coat???
cheers
Posted 03 April 2008 - 04:07 PM
A nice way to do it is to do your basecoat in the morning and laquer it in the evening before bed, then you wake up the next day and it's all done lol.
Posted 03 April 2008 - 04:27 PM
Posted 03 April 2008 - 04:30 PM
You shouldn't leave basecoat that long before clear coating there is a window of time that it should be done within if you leave it too long the chance of the clear not sticking is higher and it can start flaking off. The time depends on how/where its painted if in a booth/oven then 10-15 minuite flashoff then clearcoat if your doing it in a garage or similar then time will have to be extended to allow solvent to escape more like 20-30 min. if you do denib bits out the basecoat then you need to re base those areas or else the scratches will show through the clear.
never had any problems with the base morning clear evening method, but you're right,... ideally it should be done very soon after,.
but it's already too late for that.
Posted 03 April 2008 - 04:40 PM
Posted 03 April 2008 - 04:45 PM
well i done base last night and doing clear tonight, i thought it had to dry proper before it.
Ohh well we'll see what happens, can always be done again if need be.
Posted 03 April 2008 - 04:46 PM
Posted 03 April 2008 - 05:15 PM
Posted 03 April 2008 - 07:47 PM
Posted 03 April 2008 - 08:19 PM
I take it i leave the primer to fully dry before base??
So now iv finished the clear coat on these bits, once fully dry, 1500 wet and dry... G3 rubbing... then polish????
Mark.
Posted 03 April 2008 - 08:40 PM
Posted 04 April 2008 - 12:31 PM
cheers
Mark.
