RAISING THE REAR OF THE BONNET??
flameredturbo
, May 05 2005 08:22 PM
17 replies to this topic
Posted 05 May 2005 - 08:22 PM
HOW DO YOU RAISE THE BACK OF THE BONNET? IN MY CASE TO LET HEAT FROM THE TURBO ESCAPE.
DO YOU NEED TO MAKE UP BRAKETS?
THANKS
THANKS
Posted 05 May 2005 - 08:27 PM
i did this on my old mini with bonnet pins. i riveted triangular brakets to the corner of the scuttle and wing. and then just raised it on the pins.
however i have also seen it done using a small metal brakets on the standard hinges. i have got some close up pictures of a mini with the bonnet shut i will try and get them on for you to see.
it looked really clean!
Posted 05 May 2005 - 08:30 PM
you can do it two ways... make some brackets to fit onto the existing hinges which lift the rear level of the bonnet. or do away with the hinges all together and then just mount the pins high enough to raise the rear..
One word of warning.. Air will not be sucked in, but sucked out, as a depression is caused at the back, unfortunately this sucks all sorts of C**p up from the road and bottom of the engine into the engine bay...
My engine bay is evidence of this !
Posted 05 May 2005 - 08:31 PM
People normally remove the standard way of opening bonnet.
Then weld in triangles across the corner of wing and scuttle. mount 2 bonnet pins there, adjusting height required to give you the gap you want.
The front of bonnet can be pin'd or as my mate uses, a piece of metal welded to inside lip which slides thru the bonnet catch area.
Pin in corner...
Pin in corner...
Posted 05 May 2005 - 08:34 PM
shame about the mess getting sucked up, but would be more of a shame to have it melt all the wires near the bulkhead!
Posted 05 May 2005 - 08:37 PM
why don't you re-route the loom inside out of the way ?
Posted 05 May 2005 - 09:19 PM
jordie what carb/airfilter set up is that?
Posted 06 May 2005 - 02:06 PM
HS4 and standard filter.
and about a week after that photo, it looks like this
This aint my car, its |^Kane^| but he dont visit forums much.
Posted 12 August 2005 - 10:50 AM
I've been running my city with some brackets made from 4mm ally for the past 18 months (done about 10k) in all weathers including monsoon type rain (where even stg2 makes no difference) and with out a grill, and the engine bay hasn't got massivly dirty, no more than I would have expected running with out the grill any way
Posted 19 August 2005 - 08:02 AM
u sure that wasn't a HS2 with Standard airbox
Posted 08 September 2005 - 04:10 PM
Easiest way of doing this is to, where the hinges are still use the front hole and stud, but hitch the stud from the rear of the hinge UNDER the bonnet bracket, hence raising the back of the bonnet easily!HOW DO YOU RAISE THE BACK OF THE BONNET? IN MY CASE TO LET HEAT FROM THE TURBO ESCAPE.
THANKS
Check out the picture for results-
Posted 28 September 2005 - 06:24 PM
many of us on the B2N run found this quite a good idea, and copied
Posted 04 October 2005 - 08:48 AM
Id of thaught cutting some alloy plates about 1inch deep, and a few inch long. Then drilling 4 holes in each plate, In the correct places to line up with the existing holes in the bonnet and hinges.
The wider the holes are apart on the plates, the higher the bonnet lift.
Then simply use the existing bolts to secure the plate to the bonnet, and source another set of bolts to attach the home made plates to the hinges.
Surely this would be the easiest way.
<|Ben|>
<|Ben|>
Posted 04 October 2005 - 08:32 PM
Do you have a pic of this mod?
Posted 06 October 2005 - 11:55 PM
here, I did mine today.
It was a case of cutting 2 squares of ally plate. drilling 4 holes in each one, and then putting it inbetween the bonnet and the hinge (to extend the lift)
Took a bit of setting up, had to bend the lock at the front forwards a bit so it would go in the hole.
<|Ben|>
<|Ben|>
