Which Turbo Diesel Engine?
Posted 08 April 2008 - 08:36 AM
Which turbo diesel engine would fit into a standard mini front?
I want a really tuneable engine that can give me at least 200bhp with loads of torque.
Thinking of putting one in a mini, winding the boost up and having a sequential gearbox too.
Should be very very fast on acceleration then.
Matt
Posted 08 April 2008 - 08:40 AM
Posted 08 April 2008 - 08:48 AM
First find one which will accept a sequential box... but if you want reliability go for a VAG or PSG diesel
VAG are volkswagon/audi etc etc but what is PSG?
Matt
Posted 08 April 2008 - 08:49 AM
why is it psg
Edited by wolfys_mini, 08 April 2008 - 08:50 AM.
Posted 08 April 2008 - 08:53 AM
Im probably going to be restricted to a 1.4 or lower due to the size of it? , but the 2.0 td golf engine would be amazing if it would fit.
Matt
Posted 08 April 2008 - 08:54 AM
Posted 08 April 2008 - 09:08 AM
VAG, all very well, to fit into a mini the Polo is prob best.
D
Posted 08 April 2008 - 10:33 AM
and the vibrations that'll run through the car, you'd be better off doing it properly with on of the PROPER VAG 2'0L TD's
above is only my opnion
Posted 08 April 2008 - 10:39 AM
the only "sensible" (ie not the diesel R8) production diesel that will do 200bhp is the 1 series bmw 123D, 205bhp , due to twin turbo variable vane set up.
vag 1.9 TDI IIRC can be mapped to about 180, 190 bhp without internal mods. with mega money you can get 250brake
Edited by maph2, 08 April 2008 - 10:40 AM.
Posted 08 April 2008 - 11:26 AM
one minute you want 200bhp from a diesel then the next you only want a 1.4?
I beg to differ, currently working on the new transit, and the new engine line up is astounding!
Posted 08 April 2008 - 11:34 AM
don't recall any current ford 4 cyl diesels that can match VAG or BMW diesels. IIRC the "duratorq" diesel are rehashed Endura's with common rail tech. also IIRC they only go up to 150brake. even the 2.2L is still down on power
Edited by maph2, 08 April 2008 - 11:39 AM.
Posted 08 April 2008 - 11:42 AM
Posted 08 April 2008 - 11:45 AM
if your going to all the trouble why settle for a 1.4, you'd be over taken by the milkman AND his grandmother!!
never driven a small capacity diesel then?
obviously not!
shurrup til you got sumin decent to say
Posted 08 April 2008 - 02:18 PM
I would much prefer to have a big engine in (if i could fit it in) , just for the fact it would be sooo much faster.
Is there a 2 litre td engine thats tuneable, fast and reliable that exists?
Matt
Posted 08 April 2008 - 02:51 PM
obviously not!
Just to put my opinion in.
The 1.5 engine is dreadfull. Noisy, none revving and agricultural. The NVH (Noise and Vibrations) if it were fitted to a mini would be dreadfull without a serious investment into rubber engine and subframe mounts.
Nothing sounds like or returns the crisp response of a 4 stroke petrol engine.
