I need to fit a new outer sill on my car (expect more question on that later ) and i'm going to buy an angle grinder tonight.
Which one shall i buy out of these 2:
http://www.halfords....ategoryId_76862
Which would be best for multi-purpose grinding and cutting?
Do i need variable speed or is that really only for sanding/buffing?
Grinder - Which One?
mike.
, Apr 09 2008 03:33 PM
10 replies to this topic
Posted 09 April 2008 - 03:33 PM
Posted 09 April 2008 - 03:55 PM
If all you want is to cut the sill off, then first one is fine, never needed variable speed on a grinder.
Make sure you get plenty of cutting disks you go through them pretty quick.
The 2nd one with variable speed is pretty cheap though.
Posted 09 April 2008 - 04:10 PM
Well I wouldn't advise buying either, get a decent one that won't break in 5 minutes! but for what you want, the first one would be more suited. Don't need variable speed for grinding or cutting.
Posted 09 April 2008 - 04:27 PM
halfords don't make the best tools and they are over priced b&q do there budget range of grinders which are about £4-5 cheaper, I bought one similar to the second one, for £21 from b&q and have done a full resto with it no probs. Although you don't need variable speed for the job in hand, you might need it later, handy when you get a sanding disk or wire brush on it.
Posted 09 April 2008 - 05:36 PM
I broght mine from Screwfix http://www.screwfix....4-Grinder-240V#
More expensive ones are probably a better option if your a professional using them day after day, but for home DIY get a cheap one, that one of mine as totally rebuilt one mini, done 1/2 another and repaired a boot floor on a 3rd, still going strong
Why pay £40 upwards for a better make ?? for £15 a time I could buy nearly 3 cheap ones.
Edited by lrostoke, 09 April 2008 - 05:37 PM.
Posted 09 April 2008 - 05:50 PM
Is that the Ferm one? I bought a Ferm one for my dad and it cut through 2 pieces of corrugated iron then the bushes burned out.
Posted 09 April 2008 - 06:06 PM
No its called Direct Power I totally agree if your using them on a daily basis get a good make, but can honestly say this is my 2nd cheap grinder the previous one was a Power Devil and that one rebuilt 2 Landrover chassis's had it for years..
The only bad experience I had with a grinder was a Homebase 9" grinder, gears went in it, but give them there due they replaced it and it was nearly 12 month old that one suffered same fate though so I now have a Black & Decker for my big grinder, that ones been fine.
Posted 09 April 2008 - 07:02 PM
i got a grinder from b&q for £8 and its lasted me ages lol
Posted 09 April 2008 - 08:05 PM
Cheers guys -Went with the variable speed in the end - Decided i could make use of it for waxing my car since it comes with those attachments.
To be honest i've never really had a problem with any halfords tools - I've got a demel and sander and they're fine. The dremel i use all the time and thats great, the attachments have lasted me a while too. The sander seems fine to - Sanded down all the interior floors with it Worked a treat.
At the end of the day, i work there - So if they pack up i can get a return easily.
Posted 09 April 2008 - 08:15 PM
on the subject of grinders....
After having both cheap and expensive, I've found the best option is to plump for multiple cheap ones with a years guarentee ( eg Wickes )
Expensive ones are great keep going and going, but when you find you need new brushes for the motors, you get stung in the arse for silly amounts...
Cheap ones, I have 3, one has a sanding disk one a cut off disk and the other a wire brush, that way I don't keep having to change bits over for different jobs, saves knackering the locking button... also means jobs are done quicker, and @ £15 quid a pop when it goes wrong you either take it back and get a replacement if still under gaurentee or bin it and buy another...
Posted 09 April 2008 - 08:17 PM
I agree with guessworks, bought a couple of draper grinders at £17 each, blew the snot out of them within 6 weeks and kept taking them back!!!
No profit here!!
No profit here!!
