No Spark
12 replies to this topic
#1 mozza06
mozza06
  • 13 posts
Posted 09 April 2008 - 09:30 PM
Hi
Can anybody give me some pointers. Running fine doin 60mph just cut out no misfire nothing now won't start. Has no spark
had good spare coil,cap,leads no differant. Any ideas.
#2 BoyracerAU
BoyracerAU
  • 269 posts
Posted 10 April 2008 - 12:34 AM
What car are you in?
First up, check all your connections, especially at the coil.
If it's EFI, it could be your crank angle sensor. This sensor tells the ECU when to fire. From what I've heard, CAS's can just die - that's it. It's not always the case, though. In my car, the CAS was just dodgey, which made it hard to nail.
When you turn the key, do you hear the fuel pump prime as usual? Do you hear the idle stepper motor wind out when you turn the car on and off? Do you get lights on the dashboard? A bit more info would help.
Edited by BoyracerAU, 10 April 2008 - 12:31 PM.
#3 mozza06
mozza06
  • 13 posts
Posted 10 April 2008 - 06:52 PM
Hi yeah it's a SPi connections all good, fuel pump ok, stepper winds out,everything panel lights,etc ok. Can i check the crank sensor
#4 Ethel
  • 26,772 posts
Posted 10 April 2008 - 06:57 PM
SPI's have a Dizzy and ignition that's separate from the fuel system. Check there's voltage getting to the coil.
edited for talking b*!!*cks
Edited by Ethel, 11 April 2008 - 01:16 PM.
#5 DaveRob
DaveRob
  • 703 posts
Posted 10 April 2008 - 07:08 PM
As Ethel says .... so check the spark comming from the coil ie the wire going to the CENTER of the dizzy... ie do you have a spark comming out of your coil.... then take the distributor cap off and check the state of the rotor arm, cap and contcts...... althought the distributor DOES NOT alter the timing on an SPi... it does distribute the spark to the right plugs... The ECU sets the timming. After you confirm yea or nay then we can dig deeper
DaveRob
Edited by DaveRob, 10 April 2008 - 07:09 PM.
#6 mozza06
mozza06
  • 13 posts
Posted 10 April 2008 - 08:57 PM
DaveRob
Hi
11.5 Volts at coil, new coil,cap,etc fitted, had spares. No spark from coil.
#7 Jack Jones
Jack Jones
  • 617 posts
Posted 10 April 2008 - 09:10 PM
i take it you do have ignition lights and everything still, and it cranks fine???
Edited by just_jack, 10 April 2008 - 09:11 PM.
#8 mozza06
mozza06
  • 13 posts
Posted 10 April 2008 - 09:26 PM
Yep got the lot, cranks fine
#9 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 10 April 2008 - 09:44 PM
Plugging in a diagnostic and watching the RPM data as you crank the engine will tell you if the crank sensor if FUBAR'd or not. It does sound like ethe crank sensor. Only other way is to change it for a known good sensor.
If it is the crank sensor, the injector will not squirt the fuel either, you can see this if you remove the filter housing. If you get voltage at + on the coil, then the relay pack is working ok.
Is the car fitted with a factory alarm or imobiliser? What year is the car?
#10 mozza06
mozza06
  • 13 posts
Posted 11 April 2008 - 05:32 AM
94 model, Alarm & Imobiliser been by passed.
#11 DaveRob
DaveRob
  • 703 posts
Posted 11 April 2008 - 10:53 AM
Check to see if its injecting fuel when you crank it then....if not Im going to suggest that if you cant get a diag kit to plug in its almost certain to be the Crank sensor.... is it injecting?... You have double checked the wiring from the crank sensor all the way to the ECU for cuts, shorts, plug contact corrosion etc?
DaveRob
#12 mozza06
mozza06
  • 13 posts
Posted 11 April 2008 - 03:22 PM
DaveRob
Checked for cuts,etc seems ok check tonite for injecting, just charging battery at moment.
#13 mozza06
mozza06
  • 13 posts
Posted 11 April 2008 - 06:23 PM
DaveRob
Took crank sensor off, cleaned up & refitted she's fired up & running fine. No answer prob get me a new one just in case.
Anyway cheers for all your help
