Hi all
As most know in a different post i might need to replace the rings, i was wondering if i should change the cam while i have it appart.
It has a 544 cam from mini sport at the moment, is there a cam that would run better with my supercharged engine??
It is a 1400cc supercharged, stage 2 head, powermax 73.5mm pistons, duplex timing gears.
Also is there anything else that might work better with a supercharger while it is in bits.
Cheers in advance
Different Cam?
Elfin
, Apr 10 2008 08:59 AM
3 replies to this topic
Posted 10 April 2008 - 08:59 AM
Posted 10 April 2008 - 06:37 PM
Personally I would have a different set of pistons put in say some omega dished ones and bring down the compression ratio that way instead of a thicker gasket. and save your other pistons if you diced you want to go normally asp again. In my opinion this is the best and safest way of bring the first stage of compression down and I have seen omega Cast piston producing BIG horse power without the risk of melting.
I am running a 286 scatter cam in mine but havent had it out yet on the road, so will let you know when I do. yours should handle this cam as you have Bigger CC aswell. and the power band on this cam fits well with the revving limit of the Supercharger
Hope this helps
Hope this helps
Posted 11 April 2008 - 01:09 PM
i have a kent 286 cam for sale if your interested elliot, there a little lumpy at idle but as rpmminiman has said would go really well with your spec
pm me if your interested
Posted 11 April 2008 - 01:59 PM
I'd speak to the turbo boys on turbominis, or someone like vmax who have a lot of experiance with the supercharger conversions. Thers a bit of difference with cams when using forced induction - well, turbos anyway - they tend to use short duration high lift cams with very little overlap, i'd imagine its the same for superchargers.
