I know nothing about ICE, so can someone tell me why my stereo cuts out when I have it loud?? I've got a Kenwood head unit, Alpine amp and some kind of sub...
If I turn the volume up above a certain point, it cuts out.
Cutting out?
Bluemini
, May 08 2005 07:44 PM
8 replies to this topic
Posted 08 May 2005 - 07:44 PM
Posted 08 May 2005 - 08:20 PM
normallly associated with your earth being poo, or your gain turned up too much in my experience
Posted 08 May 2005 - 08:25 PM
Earth is ok, but what is gain when its at home?
Posted 08 May 2005 - 10:42 PM
its an adjustment on the amp, turn it down! my m8s amp was turned up too much and suffered from the same symptoms!
Posted 09 May 2005 - 09:39 PM
Have tried that and it doesn't go any louder.
Posted 09 May 2005 - 11:23 PM
its the amplifier tripping out mate, its nothing you can fix unless you turn all the bass down on THE HEAD UNIT
if it still does it, dial down the amplifiers gain
if it still does it then, you need to get your multimeter out and get to grips with mr amplifier
Posted 09 May 2005 - 11:24 PM
oh and gain is covered in my FAQ at the top of the main ice menu
Posted 09 May 2005 - 11:28 PM
I had this problem with my old head unit and it turned out it was a loose conection INSIDE the head unit its self.
Dont want to push you off track here into thinking it is this or anything. But just to let you know.
<|Ben|>
<|Ben|>
Posted 10 May 2005 - 12:18 PM
its entirely possible that its a loose connection somewhere, either in the head unit or amplifier, and when vibration kicks in, it shorts the connection, but unless your competant in electronics i wouldnt dare think of trying to fix this problem
