Combination Metric And Imperial Sockets...
16 replies to this topic
#1 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 13 April 2008 - 06:37 AM
Don't know if anyone else has come across these but look like the answer to that 'metric' vs 'Imperial' problem so many people have with Minis..
Sockets which fit both ( and a lot more )
Made by King willy ( a renowned quality tool maker ) called Powerbuilt Spearhead and come with a lifetime warrenty
I bought one to have a play with, cost about £10 ex vat
it fits 29mm 1.1/8" and E36, but also square and 12 point heads.
[attachment=56058:13042008001.jpg]
[attachment=56059:13042008002.jpg]
#2 nev_payne
nev_payne
  • 2,249 posts
Posted 13 April 2008 - 07:17 AM
Doesnt that give a lot of lea-way for slipping?
#3 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 13 April 2008 - 07:22 AM
get out in the garage and take something a part and let us know how good they are
#4 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,147 posts
  • Name: Sean
Posted 13 April 2008 - 08:22 AM
Similar claims were made for the metri-inch range of tools, unfortunately it just meant that that they didn't fit anything properly!!
They look like a less brutal version of these
http://www.lawson-hi...p;product=26933
I've got a set of the above and they are brilliant at removing damaged/rounded/rusty bolts and nuts, especially good a mini door hinges!!
Interested to know how you get on
Seamus
#5 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 13 April 2008 - 08:30 AM
It's sort of like two 6 point sockets in one, so yes you do need to ensure you have the socket positioned correctly on the head of the nut/bolt for the right size, but when you get it right you know as it's a snug fit. Also the more modern disign which drives on the flats rather than the corners....
They are fairly new to the market and I havn't found any supplier on the internet as yet...
#6 matt615
matt615
  • 923 posts
Posted 13 April 2008 - 08:36 AM
I'm not convinced about this. 29mm & 1 1/8" are different sizes, anything that claims to fit both will probably just fit both badly.
I don't see why anyone would have a "metric v imperial problem" with a Mini. 95% of nuts on a Mini are imperial. Just buy yourself a set of decent imperial tools that will fit properly. On the very rare occasion you may need a metric tool, just go and buy yourself a cheap single tool for the job.
#7 Jammy
Jammy
  • 25,397 posts
Posted 13 April 2008 - 08:43 AM
Maybe a few of us have both a Mini and a second car...
#8 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 13 April 2008 - 08:52 AM
You not quite getting it....
A 29mm head will ONLY fit one way into the socket... providing a perfect fit
A 1.1/8" (28.6mm approx) fit's two ways but one is a little slack and one is that perfect fit...
anyway... just thought I'd make people aware of a new tool on the market... I don't sell 'em
#9 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 13 April 2008 - 10:36 AM
what about some one like me who owns a mini (imperial) and a old VW (metric)
#10 jack_marshall
jack_marshall
  • 2,540 posts
Posted 13 April 2008 - 10:42 AM
I bought a huge set of these from Walmart in Florida a few weeks back for about $20!
Theyre the dog's danglies!
#11 *DJH*
*DJH*
  • 4,972 posts
Posted 13 April 2008 - 10:47 AM
they look quite good :lol:
#12 matt615
matt615
  • 923 posts
Posted 13 April 2008 - 10:59 AM
Well I own a Mini (imperial) and a Renault (Metric) as an everyday car. I just have a set of imperial tools and a set of metric. It's not expensive to have a set of each, probably cheaper than buying a set of these new tools.
However I do seem to have misunderstood how these tools work. If they fit on 2 ways, one for metric and one for imperial then it seems a good idea.
Edited by matt615, 13 April 2008 - 11:02 AM.
#13 Shifty
Shifty
  • 13,147 posts
  • Name: Sean
Posted 13 April 2008 - 11:26 AM
You could get rid of the VW, problem solved!!!(runs and hides)
#14 Ethel
  • 26,073 posts
Posted 13 April 2008 - 11:36 AM
The Metrinch stuff was my weapon of choice for rusty exhaust fittings :lol:
Only issue with Guessworks find would be using it without a ratchet. wouldn't mind a piccy with a nut in it to see where it drives.
#15 sway
sway
  • 125 posts
  • Local Club: Not Yet!
Posted 13 April 2008 - 01:25 PM
OOH harsh! There are more of us old VDub fans out here than you might think! :lol:
I like the idea as I find it difficult to work with imperial sizes. To me an 1/8" is actually 3mm (or there abouts!).
