my bottom dash rail has come away from the metal does this mean a new bottom rail is need or can it be fixed some how glue dont work at all
Bottom Dash Rail
blister
, Apr 13 2008 11:12 PM
4 replies to this topic
Posted 13 April 2008 - 11:12 PM
Posted 14 April 2008 - 07:00 AM
Where abouts has it come away? because they are fixed with the crome strip, clips and glue.my bottom dash rail has come away from the metal does this mean a new bottom rail is need or can it be fixed some how glue dont work at all
Lloyd
Posted 14 April 2008 - 07:15 PM
far left
Posted 15 April 2008 - 01:14 PM
It depends what exactly has happened. Your first post can be interpretated in a few different ways.
Are you saying that the lower dash rail trim (it's like vinyl covered sponge) has come away from the dash rail? If you are, you could use a contact adhesive such as evostick to glue it back in to place, but good luck removing it.
If you're saying the metal rail itself has broken away from the points where it joins the door pillar then you're going to have to have it welded back on.
Posted 15 April 2008 - 05:38 PM
hi its the plastic part i have tried lots of adhesives its just so strongly sprung it wont adhera
