Boot Lip Repair
8 replies to this topic
#1 nomininolife
nomininolife
  • 982 posts
  • Local Club: Mini Mates
Posted 14 April 2008 - 08:05 PM
Hi guys
I am in the process of repairing the boot floor, story as usual holes along the rear edge and above the valance closing panels.
Now the thing is that the rear panel/bumper lip is a bit shabby, bits are solid and bits have corroded through. But, the rest of the panel is sound and I dont want to cut away good metal and spend £105 on it.
Would I be able to use this panel http://www.minispare....aspx?pid=36457 ?
In my eyes theoretically it is the same shape so it should fit.
Feedback is much appreciated.
David
#2 mighty mini jack
mighty mini jack
    Mighty Before a Pint
  • 5,095 posts
Posted 14 April 2008 - 08:17 PM
That Panel should weld onto the rear panel when you grind/cut away the old one.
#3 panelbeaterpeter
panelbeaterpeter
  • 5,606 posts
  • Local Club: n/a
Posted 14 April 2008 - 08:55 PM
Obviously that panel is for the front, but seeing as mini saloon bumpers are the same either end, it shouldn't be far off. It may need a little trimming and fettling, but it should work.
#4 nomininolife
nomininolife
  • 982 posts
Posted 14 April 2008 - 09:01 PM
Thanks Guys
I know it will need a bit of manipulating, but if it saves cutting into good metal and £105 its worth doing.
David
#5 jack_marshall
jack_marshall
  • 2,540 posts
Posted 14 April 2008 - 09:13 PM
If your any good with sheet steel and a pair of tin snips, why not make your own repair piece that is the perfect size for you, incorporating the bumper lip with it, so you wont have any panels to buy?
If theres not too much rust like you say it should be pretty easy.
If you cut out the problem in once piece you can also use it as a template and either butt weld it or overlap and weld it (with a joggled edge would be best!)
Just an idea though.
#6 nomininolife
nomininolife
  • 982 posts
Posted 14 April 2008 - 09:16 PM
Thanks Jack
Great idea, I dont mind spending the £10 or so, I could do the same with that panel without the messing with a fresh plate.
Like I say really good idea.
David
#7 mini_kel
mini_kel
  • 2,851 posts
  • Local Club: EMC/No pub mini club
Posted 14 April 2008 - 11:07 PM
I can get a repair panel that does boot hindge and under the rear lights includes the lip you are after £80 +postage
I`ll find the pic
#8 mighty mini jack
mighty mini jack
  • 5,095 posts
Posted 14 April 2008 - 11:14 PM
I`ll find the pic
It will be something like this (the black bit welded on) saves you finding the pic kel
http://www.theminifo...x...st&id=56026
picture from racerlike's project thread
#9 mini_kel
mini_kel
  • 2,851 posts
Posted 14 April 2008 - 11:24 PM
I`ll find the pic
Yep thats the piece above lower rear valence :P
