Hey, i have been doing a bit of body work on a mini which i managed to get my hands on and i have needed to do some welding. However my welder dosen't seam to be great! the welds are ''blotchy'' and it spits a hell of alot when welding. I have a gassless Mig welder. can anyone tell me what could either be causing the weld to be pants (other than me) , and possibly a better type of good value welder to get please? I have a feeling my welder is just no good.
cheers i hope this is in the right section
luke
What Type Of Welder Is Best?
Flukey
, Apr 14 2008 10:50 PM
4 replies to this topic
Posted 14 April 2008 - 10:50 PM
Posted 14 April 2008 - 10:55 PM
The best thing you can do really is take a look at www.mig-welding.co.uk the is a world of knowledge on there.
Basically the steel you are welding must be scrupulously clean, no rust. Do you know how old the wire is?
David
David
Posted 14 April 2008 - 11:03 PM
couple of days old, picked it up the other day, so I wouldnt have thought that would be the problem?? Thanks for the link ill check that out!
luke
luke
Posted 17 April 2008 - 10:17 AM
Gasless welders to spit a hell of a lot, the welding wire has a flux through it. If your getting really splattery finish it might be worth checking you've the wire speed right, on the cheap-ass gassless ones (i had one), you need to make sure you've not overtightened/or under tightended the wire feed tension roller.
I went through 2 1/2 small rolls of flux wire, and i found one of the rolls was just mince, i thought i'd sussed it with the initial half reel, but the first halfords one spattered like crazy, i ended up grinding all the welds off and starting again.
Posted 17 April 2008 - 08:39 PM
Try and borrow/bed/steal/borrow a proper gas mig.
Theyre so much easier to use and produce much better results.
If your looking for a new welder, 100-150amps is good for mending mini's!
Ive found the one with variable wire speed and amps better than one with '1,2,3,4' settings.
www.machinemart.co.uk is a good place to look, as theres alot of stores nationwide.
Good luck!
Good luck!
