OK.... replacing the above. Both wings, A panels and front panel...... what order do I change them in or is it all off and all new on....... was thinking it might be better for alignment reasons if their was an order to do this in.
Thanks in advance
DaveRob
Wings, Front Panel And A Panels
DaveRob
, Apr 15 2008 10:23 AM
3 replies to this topic
Posted 15 April 2008 - 10:23 AM
Posted 15 April 2008 - 10:32 AM
i dont know if its the correct way but ive ripped all mine off and im going to start putting it back togeather starting fron the front.
once its all in place and lined up and held together with clamps,i will then tack weld it all togfeather,a small bit at a time to keep the heat down.
Posted 15 April 2008 - 11:38 AM
this has just been done recently, but to save you searching.
cut all the panels off, check the bonnet alignment at the back, next to the scuttle, adjust if needed to get a correct gap.
fit the front panel and align the bonnet peg so it drops in place on the front panel, tack in place, now fit the wings, adjust as needed to get the correct gaps at the side and aligns with the front panel and tack into place, now fit the apex panels and weld it all up.
Posted 15 April 2008 - 12:35 PM
Thanks for your help..much appriciated
DaveRob
DaveRob
