Spray Gun Question
frankiebateman
, Apr 15 2008 01:22 PM
8 replies to this topic
Posted 15 April 2008 - 01:22 PM
I have seen a spray gun at my dads work and i was just wondering is it all right for using to spray a car with ? heres a pic of it to show you what kind it is, i dont know the model or make but i think its been used for painting & decoraring thanks
Sorry for the rubish quality
Posted 15 April 2008 - 05:12 PM
Hard to say without some info or a better picture.
Get a name off it and model number if there is one.
Posted 15 April 2008 - 05:31 PM
thats normally used for painting large things, lorries for example. bit over kill really unless you ar efamiliar with how it works.
Posted 15 April 2008 - 09:36 PM
What Rozzer said is spot on. They're for commercials really, it has a big separate pot so you can get more paint in at a time. Not suited for cars unless you get a very small fluid setup and practice with it. they tend to throw the paint on very thickly, which causes bad orange peel or runs! Oh and it's a Devilbiss JGA.
Posted 15 April 2008 - 10:03 PM
Thanks for that guys, so ill not use it then i dont want a :xxx:ed paint job thanks alot
Posted 15 April 2008 - 10:17 PM
So thats the Devilbiss JGA pressure feed then, ive got the Devilbiss JGA Suction feed, I got confussed with that
Pete do you know if need a 1.8mm needle for my gun?
Edited by mighty mini jack, 15 April 2008 - 10:19 PM.
Posted 16 April 2008 - 07:32 PM
Depends what you want to do with it. A 1.8 is only really suitable for primer. For general basecoat, lacquer and solid gloss, you would be best off with a 1.4 setup.
Posted 16 April 2008 - 07:38 PM
OK thanks, do you know where i can get new needlesDepends what you want to do with it. A 1.8 is only really suitable for primer. For general basecoat, lacquer and solid gloss, you would be best off with a 1.4 setup.
Edited by mighty mini jack, 16 April 2008 - 07:38 PM.
Posted 16 April 2008 - 07:57 PM
Any bodyshop supplier, or try ebay. You won't just need the needle, you need a whole new fluid setup which consists of the needle, fluid tip and air cap.
