Hey
ive found some rust in the rear bins now here are some pics
passenger side
cleaned it up abit and put some hammerite on the ones that didnt crumble
drivers side one is solid for the moment, i poked it with a screw driver and it didnt crumble
Any tips on how to tackle this ?
I know its going to be very very very very hard to do as the bin comes in the way and its going to be awkward having the mig torch in there
ive thought about removing the rear bin properly via the spot welds and then plug welding it back in but then plug welding it inside the bin will be abit tedious but it could be done ? and im going to have to look at bracing ?
any tips ?
thanks
Rear Bin Rust !
GreaseMonkey
, Apr 18 2008 01:51 PM
6 replies to this topic
Posted 18 April 2008 - 01:51 PM
Posted 18 April 2008 - 02:01 PM
Mine are worse than that
Posted 18 April 2008 - 02:04 PM
I know how it feels with just that little hole
its such a awkward place for it to be in
Posted 18 April 2008 - 02:34 PM
Pah, mines much worse than that!!
Best and easiest way would be to remove the sill and attack it from that side.
Oh yeah, and this is mine
[attachment=56550:spudnik_floor.jpg]
Posted 18 April 2008 - 02:42 PM
The outer sills are going to come off
will that help getting to them ?
Posted 18 April 2008 - 03:02 PM
Yes, the rust you can see is part of the inner sill, when the outer sill(the bit you can see from the outside) is removed then you will have full access to this rust.
Cut it out,make a repair section and weld it in, job done!!
If you don't want to make up repair sections, then you can buy an inner sill repair section and cut your repair panels out of this.
Posted 18 April 2008 - 03:11 PM
Thanks alot
am i glad or what that ive found out theres a nice way of doing this
