Overheating & Low Oil Pressure
8 replies to this topic
#1 wolfys_mini
wolfys_mini
  • 2,493 posts
  • Local Club: many!
Posted 20 April 2008 - 10:34 AM
morning
overheating and low oil pressure....
ideas on what causes both please.....
the low oil pressure just came on, was ok one minute and not the next...
and the same for the over heating....
cheers
edit: more then just "have you got oil and water in it" :D
Edited by wolfys_mini, 20 April 2008 - 10:34 AM.
#2 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,154 posts
  • Name: Sean
Posted 20 April 2008 - 01:06 PM
Have you put oil and water in it?(?/??????????)
Is the car actually overheating or are the guages just saying that is is?
I only ask because I know that you have had wireing issues lately.
#3 Ethel
  • 26,593 posts
Posted 20 April 2008 - 01:10 PM
How low is low oil pressure?
Either could be caused by the other, let's hope the temp caused the pressure drop.
#4 wolfys_mini
wolfys_mini
  • 2,493 posts
  • Local Club: many!
Posted 20 April 2008 - 01:24 PM
not on the mini :(
i have had a v6 cologne engine overheat when being driven normally
and a pinto engine have the pressure drop to zero when running up a drag strip this weekend.
i have a scribbled down list of bits that may have caused them, but was seeing if you could come up with any newens :(
#5 wolfys_mini
wolfys_mini
  • 2,493 posts
  • Local Club: many!
Posted 20 April 2008 - 02:20 PM
bump :(
#6 alexcrosse
alexcrosse
  • 3,786 posts
Posted 20 April 2008 - 03:17 PM
they go hand in hand. If it over heats it will have low oil pressure too. And considering last time i saw you your rad was pisin out water its probably that. Put a nice 4 core rad in and new pipes, see how you get on.
#7 TimS
TimS
    Mini Doctor
  • 2,712 posts
Posted 20 April 2008 - 03:24 PM
Could be numerous thing whats the back groudn on the Pinto engine has it been apart recently? Could there be anything blocking the oil galleries up? Have you checked any other things such as compression?
Edited by TimS, 20 April 2008 - 03:24 PM.
#8 wolfys_mini
wolfys_mini
  • 2,493 posts
  • Local Club: many!
Posted 20 April 2008 - 03:27 PM
it has been re-built recently new bearings and arp bolts, nothing has been checked as of yet, due to it being a sunday :(
#9 mini_mad69
mini_mad69
    Let future you worry about it
  • 5,417 posts
  • Local Club: urrrr no
Posted 20 April 2008 - 05:57 PM
This is just a guess i may be saying something stupid but here goes, could it be your head gasket? water in the oil and oil in the water, just a possobility as when my gasket went my egine heated up quite quick.
