Wheel Noises
Posted 24 April 2008 - 09:08 AM
The noise comes when i brake and turn left more and usualy only starts a few hundred feet after begining my journey can some one please advise me what it is, cause its driving me round the bend
Posted 24 April 2008 - 10:41 AM
i might be wrong but worth a try
cheers
Posted 24 April 2008 - 11:18 AM
have you tried the wheel barings?? i know they squeel if there breaking down or been over tighted??
cheers
Yeah tried bearings fitted brand new 5 mins ionto test drive noise came back
Posted 24 April 2008 - 11:45 AM
Posted 25 April 2008 - 08:38 AM
what size wheels do you have??? i have had the prob because i put metro brakes on and 13" wheels and it was rubbling on the mettel wheel arch where i had not cut egnuff out.
I have got 12 inch revolutions on i have checked for fouling on the arch and cant see anything catching i have been told this may be a outer CV joint problem but not sure because its not knocking any thoughts?????
Posted 25 April 2008 - 09:15 AM
Posted 25 April 2008 - 09:37 AM
I've been getting a really horrible grinding noise coming from my front drivers side wheel, Im pretty sure that it is the brake pad grinding on the disc, I have no idea how to stop it!!
Again thats something i have tried i replaced both pads and discs. If yours is happening just when its braking then i would say its either the pads are running low or if its happening all the time then it could be your calipers sticking. The way to do that is to take out the pads and check the caliper and the piston. This pushes the pads on to the disc. Check for wear or pitted marks around the cylender shaped piston to see if its catchin, if it is worn then get a replacement. If its the pads that are worn theses are easy to change just remeber the brake grease.
I would love to know whats causing my noise its driving me made
Posted 25 April 2008 - 09:41 AM
Posted 25 April 2008 - 09:45 AM
I replaced mine too, but they are still doing it! Mine happens when I am just driving, but stops when I brake. Both by stepdad and boyfriend have had a look and checked over all my brakes, but cannot find anything wrong. It is driving me up the wall too!! They took the pads out 2 days again and copper greased them, but haven't stopped it!
Its a nightmare i know, I am running out of things to do to mine , youd think that a small part of the car it would be easy to find.
Iwould suggest to give your cylinders a dismantle and a good clean to see if they are catching otherwise we both have noisy mini's. I have been told that wheel bearing sometimes play a part in noises from them breaking down inside the hub. you can check this by jacking it up and seeing if there is any play in the wheel.
Posted 25 April 2008 - 10:30 AM
Posted 25 April 2008 - 10:50 AM
Samuel:
What was the condition of the bearing like when you changed it. How easy did the outer race of the new bearing go into the hub? Was there any evidence of the outer race spinning in the hub? I say this because a bad bearing that is left can force the outer race to spin inside the hub, wearing it larger, so you will never get the same fit, even when fitting a new bearing - and the same will happen.
Same to Sazal, did you personally fit the bearings?
Posted 25 April 2008 - 10:58 AM
Ok, we have two threads going on here!
Samuel:
The bearings realy wernt that badley worn they were probably not the main cause everything was in place and looked ok the new berings went in like a dream
Posted 25 April 2008 - 11:03 AM
Samuel:
Yeah, sorry for hijacking your thread!
Ill reply in my squeaky wheel thread!! Squeaky Wheel!
Posted 26 April 2008 - 06:36 PM
Samuel:
Yeah, sorry for hijacking your thread!![]()
can any one else help
Posted 26 April 2008 - 07:29 PM
i have recently had the following changed on frank the mini
-wheels (4.5x12)
-front rubber cones(added hi-los)
-front dampers
-tie bars
-front subby mounts
-top engine steady bushes
-alternator/fan belt (what a job
-plugs leads and airfilter
the sound is still there and driving me mad as i have no radio to drown out the noise,i will be doing the following the giving up
-new disc's/pads
-wheel bearings
-subframe top mounts
-engine mounts
-lower steady bushes
and when all that fails i'll just fit a loud radio
