i've got exactly the same problem!!,squeaking/grinding sound drives you mad.i know my wheel bearings need doing,plus i suspect the engine mounts and subframe mounts need doing too,all these contribute towards the sound.
i have recently had the following changed on frank the mini
-wheels (4.5x12)
-front rubber cones(added hi-los)
-front dampers
-tie bars
-front subby mounts
-top engine steady bushes
-alternator/fan belt (what a job)
-plugs leads and airfilter
the sound is still there and driving me mad as i have no radio to drown out the noise,i will be doing the following the giving up![]()
-new disc's/pads
-wheel bearings
-subframe top mounts
-engine mounts
-lower steady bushes
and when all that fails i'll just fit a loud radio
I must admit that the loud sterio does dround the sound out, what do you think about the fact it could be a CV joint i'm not sure whether to try or not
