Has anyone done this?
Cut out existing rusty windscreen frame.
replaced it
Mig welded in place?
pic's would be appreciated!
Drilling Out Windscreen Frame
rumplitter
, Apr 29 2008 10:02 AM
3 replies to this topic
Posted 29 April 2008 - 10:02 AM
Posted 30 April 2008 - 01:39 PM
Had a go last night at drilling out the spot welds, easier than i thought!
Quite happy doing the sides but I've no idea how the top of the screen/gutter is attached?
help please!
help please!
Posted 30 April 2008 - 02:07 PM
I have replaced a few windscreen panels in my time, fortunately I have never needed to replace it right up to the roof area, have you a picture of the top of the replacement windscreen panel, from memory I seem to remember it coming with part of the drip rail which as I said I didn't need to use.
If you need to use it you will need to remove that drip rail on the car and fit your new panel into the gap, your spot weld driller won't be much use for this, a grinder will do it no problem just be careful not to damage the surrounding panels, I prefer not to disturb the roof / drip rail area if possible
David
David
Posted 30 April 2008 - 08:48 PM
From the factory the roof is welded to the top of the windscreen surround panel with a roller welder which works in a similar way to a spot welder in that it relies on an electric current melting the two panels together but using rollers instead of points. To remove the seam, you'll need to carefully grind the original panel from below. If you can get away with leaving the top part and join the panel near the top corners it may be easier.
JR
JR
