Might be a silly question but have you checked if the bulbs are blown by any chance? Surely theres little chance of 6 of them blowing at the same time, but check anyway!
Indicators
Jules
, Feb 17 2004 01:43 PM
27 replies to this topic
#16
Posted 20 February 2004 - 04:09 PM
#17
Posted 20 February 2004 - 04:10 PM
No its definately not the bulbs because the hazards work fine!!!!
#18
Posted 22 February 2004 - 06:34 PM
thats rather odd.
#19
Posted 25 February 2004 - 05:39 PM
Ok this is silly now its been 3 weeks or something and no indicators,
tried cleaning the earths, as minis84 said, nothing
taken the coloum off to see if there was something suspect there, no.
Changed the in-line fuse box, nothing.
What else could it be?? Need to get this sorted because its a pain in the arse
#20
Posted 26 February 2004 - 03:13 PM
Guys Help
#21
Posted 26 February 2004 - 03:30 PM
faulty indicator stalk?
#22
Posted 26 February 2004 - 03:50 PM
Changed the whole thing and it still didn't work so knew it wasn't that. Really really stumped on this one, so i suppose i'l have to give it to someone who knows everything bout everything and pay them loads money!
#23
Posted 26 February 2004 - 08:19 PM
jules try the hazard warning switch, i had same problem but mine was other way round, i had indicators but no hazards, changed switch( wrong one) now have hazards, but no indicators, when i get new hazard switch should solve problem
#24
Posted 26 February 2004 - 08:55 PM
That could explain a few things, because I bought new switch's, because they went grey!! I'l try that tonite!!!
Cheers :grin: :grin:
Jules x
Jules x
#25
Posted 26 February 2004 - 09:16 PM
hope it works happy miniing :grin: :wales:
#26
Posted 27 February 2004 - 01:40 PM
Mmm, I have had simmilar problems in the past and just after restoring my mini the hazards stopped working. However from what I remember of the fuse box if the fuse is gone or making a bad connection then the side lights do not work either so that is an easy test. I changed my fuse box for the new blade type which is a very easy mod and is much much better.
The best thing to check if you have not done already is the hazard switch. When the hazards are on it removes the supply to the indicator stalks so the normal indicator circuit can not be operated. When you switch the hazards off the supply is restored and the hazard supply is isolated. Wether you follow that or not I am basically suggesting you try another hazard switch or at least check that it operates properly. If it has not been used for some time the contacts can become dirty and stop it working.
Ben
Ben
#27
Posted 27 February 2004 - 11:56 PM
Thank you so much cowboy and Ben. Changed the switch over (back to my old one) and the indicators work!!!!!! :grin: I'm sooooooo happy!!!!!! Thought it was going to be something really really expensive . Now I can slow down for corners!!!!!! :grin: :saywhat:
#28
Posted 28 February 2004 - 07:30 AM
:grin: :grin: :grin: :grin: :grin: :grin: :grin: :grin: :grin: :grin: :grin: :grin:
sorted, well done chaps. job done.
