Making A Fibreglass Custom Dash?
Posted 03 May 2008 - 10:56 PM
thanks
jonathan
Posted 04 May 2008 - 12:41 AM
As iv said iv done a search but all the links and pictures are broken and gone. im wanting to make a custom dashboard out of fibreglass but i havnt a clue how.. can anyone supply a guide?
thanks
jonathan
What are you wanting to accomplish? Something similar in shape to a stock dash or something more extreme with a lot of curves? There are a few ways to approach a project like this but it would be good it have a good idea of the end results you are hoping for. Do you have any pics of a style you like?
Posted 04 May 2008 - 09:52 AM
He made a net/frame out of chicken wire and wood etc and then covered it in expanding foam. once the foam has hardened you can cut it about and chop it up and sand it into the the correct profile you're after. then you can fibreglass over the top of it.
Posted 04 May 2008 - 12:12 PM
the dash will be like this
and ill be having mustang style clocks like this
Posted 04 May 2008 - 03:13 PM
Posted 04 May 2008 - 04:07 PM
Posted 04 May 2008 - 04:28 PM
Posted 04 May 2008 - 07:20 PM
Posted 04 May 2008 - 07:26 PM
Just a thought matey
Posted 04 May 2008 - 07:34 PM
Posted 04 May 2008 - 09:51 PM
Posted 04 May 2008 - 10:04 PM
Posted 05 May 2008 - 12:00 AM
Posted 05 May 2008 - 05:31 AM
So get some thin MDF and cut out the shape for the top rail and then glue the foam to it and start finishing the shape. Then apply a thin coat of resin and let it start to get tacky and lay some light glass fabric over it making sure to get it nice and tight into any corner and curve, stipple the glass it into the tacky resin and let harden. Then build up a couple more layers of fabric and go on to the bottom rail the same way. If you end up using the foam panels you can even do the center pieces in foam and add the glass on top. One advantage of using the foam here too would be that you can make indentations or glue some mdf in places before glassing, to add a little more character.
These are just some ideas and it is difficult to cover much detail so ask away and I am sure other and I can continue to give input.
Posted 05 May 2008 - 09:34 AM
