Spot-weld Drillbit
LuckyRob
, May 06 2008 07:00 PM
13 replies to this topic
Posted 06 May 2008 - 07:00 PM
I got my spot-weld drillbit from Machine Mart and its useless! http://www.machinema...4/040210467.jpg
It just doesn't seem to cut! I even tried turning it round to use other side but that wasn't any better. Has anyone else had this problem or am I doing something wrong? Or maybe my mini is made of stronger (but still just as rusty) stuff than most.
Posted 06 May 2008 - 07:08 PM
Those things are a waste of time and money. I always make my own from a normal twist drill.
Paul
Paul
Edited by Paul Wiginton, 06 May 2008 - 07:09 PM.
Posted 06 May 2008 - 07:54 PM
The second type are fantastic, the first type are *******.
Posted 06 May 2008 - 08:00 PM
Its that second type that I make myself
Paul
Paul
Posted 06 May 2008 - 09:54 PM
how do you make them yourself?
Posted 06 May 2008 - 10:04 PM
Ive use the first ype before, and like you say they are great for the first few spot weld but then the go blunt and even some of the cutting teeth come off. Ive moved over to the second type now, sooo much better
Posted 07 May 2008 - 08:40 AM
I've used the first type for over 20 years (yes I've had to replace blades a few times) never had a problem.
Posted 07 May 2008 - 07:31 PM
You just grind the sides flat, leaving a point in the middle. I've done it too, but the ready made ones are much better.
Posted 08 May 2008 - 09:30 PM
I work for a carriage builders and we use the second type.
Posted 09 May 2008 - 07:04 AM
Thanks for the advice guys. i'll try and get hold of the second type then. At least i don't feel like some kind of tool spastic that can't use the simplest of tool now either!
Posted 09 May 2008 - 07:53 AM
The screwfix spot weld drill bits are great,why on earth did i buy one of the machine mart ones,because they are C**p.Did one spotweld and it was blunt!
Posted 13 May 2008 - 10:51 AM
Anoter vote here for the second type, the screwfix ones, used loads and going great still
Posted 13 May 2008 - 06:49 PM
Just recieved my new 'second type' spot weld drill bit from Screwfix along with some new cutting discs for my grinder. Now all I need is for the weather to stay good and get some time off work so I can spend some quality time with my new tools
