Lil Help About Floor
sidq
, May 11 2008 11:47 AM
7 replies to this topic
Posted 11 May 2008 - 11:47 AM
hello all...
here's some of a pics of my mini's floor.any idea or suggestion of what should i do or fix?
http://www.flickr.co...57604994767940/
thanks.
thanks.
Posted 11 May 2008 - 08:39 PM
Hiya looked at the pics what exactly is wrong with it looks a little pushed up but not bad. Unless that tape patch is covering something ?
Posted 12 May 2008 - 06:19 AM
the tape is just to make sure that the wiring is fixed at one place.
Posted 12 May 2008 - 06:40 AM
i just snapped few more pics of my front floor panel.too bad this is what i found hiding under my carpet.
http://www.flickr.co...57605013595207/
i've already cover the hole with pyroxylin lacquer.
so i know i cant hold it for too long...should a change the front panel or just weld a patches there.
Posted 12 May 2008 - 01:34 PM
Mate thats nothing! Mine has had numerous leaks resulting in a 2" puddle in the passenger footwell for god knows how many years before i bought it and theres a load of surface rust (which is getting sorted soon!). It looks really bad but in actual fact its not rotten at all, just where the water has dried and formed a layer.
Matt.
Matt.
Posted 12 May 2008 - 02:32 PM
Matt.
Am I the only person that thinks this is a typical mini owners answer? 'that? no, that's not rust, don't be silly'. To any other car owner in the world, surface rust is a nightmare, to a mini driver it's a relief that's it's not rotten. I have to be honest though, I'm struggling to see from the pics what the problem is.
I'd have to say though that it should be your decision, if you think it's bad enough then put a new panel on otherwise it'll be the one bit that you're never quite happy with, at least if you replace it then you'll be happy that it's sorted and won't have to worry about it for a while. If you think it's not that bad and will be fine with some welding, then weld it. It's what you'd be happiest with at the end of the job.
Posted 12 May 2008 - 03:54 PM
i should've taken the pics before i cover the holes with that lacquer.sorry about that.probably i kinda get a lil uncomfy with having a holes under my feet. anyway i'll send my mini to my mechanic on wednesday and see what he have in mind.anyway thanks for the suggestions and opinions.if i manage to get a pics of the holes when my mechanic want to fix this matter i'll post em here.
Posted 15 May 2008 - 08:13 PM
i have already post the pics in another topics.thank you.
Edited by sidq, 16 May 2008 - 01:27 PM.
