when the car gets to temperature the fan just stays on constantly, its done this since ie had it
is it normal and if not what do you think would solve the problem, thanks
Mpi Fan Always On
seanc
, May 14 2008 02:54 PM
3 replies to this topic
Posted 14 May 2008 - 02:54 PM
Posted 14 May 2008 - 03:08 PM
Are you sure it's just when the car gets to normal temperature and not all the time? On my MPi, the plug connecting to the temperature sensor in the thermostat housing is a bit broken and sometimes falls off. When it does, the fan kicks in. And if I start the car with it disconnected it plays havoc with the idle as the ECU doesn't getting a correct reading from the temp. sensor.
Posted 14 May 2008 - 03:20 PM
I had the same problem,
Took the connector off the sender in the thermostat housing & cleaned with electocleaner spray & that cured the problem
Posted 14 May 2008 - 03:42 PM
excellent i`l take a closer look at that
