Advice Needed On Underseal?
1314cc
, May 14 2008 06:10 PM
4 replies to this topic
Posted 14 May 2008 - 06:10 PM
just had a repair done just above where subframe mounts so when finshed i cleaned the underseal off from all the rear then repainted
so i'd like to know wether its worth applying more underseal or is it better to leave just painted?
this was what it looked like before! and it was the same the other side!!!!
Posted 14 May 2008 - 07:11 PM
I'm no expert full stop, but people have always recommended undersealing to me. Mini's are notorious for rust and it can't do any harm.
As a note on prevention, 90% of the time, pretty much all rusting in and around your wheel arches, as well as the usual spot on the A-panel is caused by mud and debris building up in the wheel arch. It gets flung up there by the tires, gets stuck in all the little nooks and crevices and will stay there for a VERY long time, never really drying out, unless you actively clean it out form time to time.
When you wash your car it's a good idea to get a stiff brush and a steady flow of water up behind your arches and get rid of much grime as you can. make sure you get right into the corners and pay special attention to any overhangs or lips around the arch itself, especially where aftermarket arches or sportspacks have been fitted. basically just keep going until the water runs clear. Then from time to time it is worth jacking your motor up and getting the wheels off one at a time so you can really get in there and make sure those arches and all their corners are spotless, especially at the back of the front arches, behind the A-panel.
Posted 14 May 2008 - 07:39 PM
Underseal, or at least the black gooey type isn't really used at all these days unless you're trying to hide something. I'd etch prime it, stonechip it, colour it, then apply lots of clear waxoyl, cleaning and re-coating it each winter would be perfectly sufficient.
Posted 14 May 2008 - 10:57 PM
I try and put back what was once there, for example my sills has schultz on them, so that's what i put back, purely to keep it original looking etc!
Posted 15 May 2008 - 07:17 AM
Would this method allow you to continue the colour of the bodywork across the entire shell, underside and all?Underseal, or at least the black gooey type isn't really used at all these days unless you're trying to hide something. I'd etch prime it, stonechip it, colour it, then apply lots of clear waxoyl, cleaning and re-coating it each winter would be perfectly sufficient.
