moto lita steering wheel fitting
16 replies to this topic
#1 GarethP
GarethP
  • 62 posts
Posted 22 May 2005 - 07:51 AM
managed a quick picture late last night after fitting a moto lita jc sig wheel to my 1999 mpi.
nothing properly tightened up, but have an issue - wheel seems to be way too close to stalks - knuckles brush against them when turning... Is this just a 'feature'??
confused (again).
next day:
have tightened it all up now, and low and behold, haven't got it quite straight, so need to remove boss to re-align - had a quick go at getting it off, but seems stuck fast - what's the preferred method of persuasion??
#2 clydecat
clydecat
  • 14 posts
Posted 25 May 2005 - 08:56 PM
That looks sweet! Where did you get the boss?
#3 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 25 May 2005 - 09:02 PM
It's not a feature, that's just what happens when you fit non standard parts!
To get it off either use a hub puller (a three legged puller will be needed for an aftermarket wheel as they don't have the threaded holes for the special tool) or thump the back of it with a soft faced (copper, brass, leather etc) mallet. However you decide to remove it it is always a good idea to leave the nut on the end of the shaft (not tightened up obviously) by a couple of turns to catch it when it comes away. They tend to release with some force and many people have broken their own noses with a steering wheel....
#4 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 25 May 2005 - 09:24 PM
bust lip and tooth, actually !
#5 GarethP
GarethP
  • 62 posts
Posted 26 May 2005 - 09:19 AM
w&p come up trumps again - 40mm longer boss in the post.
can't praise them enough - outstanding service. Public thanks to Mike!
off to buy a hub remover after work.
thanks all.
#6 jeffriesmullet
jeffriesmullet
  • 36 posts
Posted 26 May 2005 - 06:14 PM
did the boss cost any extra?
#7 GarethP
GarethP
  • 62 posts
Posted 26 May 2005 - 07:46 PM
nowt, hence the praise ;-)
no, kidding aside, they are honestly a top-notch outfit, with superb customer focus!
#8 GarethP
GarethP
  • 62 posts
Posted 14 June 2005 - 01:35 PM
rubber hammer replaced a hub puller - dozen or so taps and it came off - put new hub on, and sorts the clearance issue no worries. think might order the steering column drop bracket now, as it does poke a bit skywards ;-)
visa card had been charged however - hoping this will be rectified when return the shorter hub...
#9 mini_sam
mini_sam
  • 1,381 posts
Posted 14 June 2005 - 06:26 PM
lo0o0o00oks smo0o0o0o0o0o0o0oth!!!! :lol:
#10 Barnett
Barnett
    Michael Jackson has died...*plop*
  • 3,395 posts
  • Local Club: the freeeeloader!!
Posted 14 June 2005 - 07:03 PM
Ive got the same!! really sweet steering wheel...i will post pictures...
Just out of interest!! " How much did you pay!! ?? "
#11 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 14 June 2005 - 07:16 PM
i see the problem you are trying to fit it on the wrong side of the car :tongue:
#12 mattvallins
mattvallins
  • 1,139 posts
Posted 14 June 2005 - 07:38 PM
Errrrrrrrr, are you not sposed to use a DISHED wheel? Like the 1 that came off? I got a deep-dish mountney wheel and am swapping an MG boss for a mini boss. The wheel cost me a quid at the tip :grin: :grin: :grin: :grin:
#13 GarethP
GarethP
  • 62 posts
Posted 15 June 2005 - 07:53 AM
barnett - paid 99 for wheel and 75 for boss - billet centre cap was 59...
drop bracket which i intend to purchase (just checking how far it actually drops the column) is 17 + vat.
not a cheap upgrade all in all, but completely changes the feel of the interior imho - really did not like the rover airbag wheel.
washing the car thursday after work - will get some decent pics...
mattvallins - the jc sig wheel is semi dished - really wanted the sig model, so no choice...
bungle - you should see what having the wheel on the left does to pedal space - heater is even more intrusive on this side, and the pedals are further off centre - makes shoe choice limiting.
#14 mattvallins
mattvallins
  • 1,139 posts
Posted 15 June 2005 - 09:30 AM
Gareth, you mean a column drop (extender that runs between the bottom of the dash and the column)? I have a spare here somewhere you can have for a coiuple of quid if you want?? 20quid seems a bit steep!
#15 GarethP
GarethP
  • 62 posts
Posted 15 June 2005 - 10:13 AM
matt - there are 2 different types - one for the standard coloumn, and one for airbagged columns - which do you have ??? the airbag one is a lot more expensive for some reason... (numbers produced i'd imagine, as negates airbag use)
see http://www.woodandpi...FTOKEN=31340278
