Hi
I was thinking of fitting alluminium door skins to my 95' sprite. Are alluminium skins weaker or harder to spray than normal steel items?
Alluminium Door Skins
1275 SPRITE
, May 16 2008 10:18 PM
5 replies to this topic
Posted 16 May 2008 - 10:18 PM
Posted 17 May 2008 - 09:36 AM
i havent sprayed mine yet, but im just going to use a normal etch primer ive been told they arent any harder to spray than steel. ive found they dent quite easily but its hard to say while they arent in paint im only guessing a bit. but the way im looking at it is they arent going to bubble up so you can always just keep filling the doors like once a year or every other year and they will still always be alright.
Posted 17 May 2008 - 05:41 PM
Treat them like they are bare metal steel skins. Etch prime, Prime, then paint.
Posted 19 May 2008 - 09:10 PM
Ok, thanks for the help.
Posted 19 May 2008 - 09:21 PM
Make sure you have some thick paint and sealant between the steel of the frame and the aluminium. If the two metals touch, you get electrolosis which corrodes both metals away. Remember once alli corrodes, you cant treat it as you can steel.
Paul
Paul
Posted 20 May 2008 - 04:25 PM
Paul
True, I forgot about that. Just need to take some major care then.
