Rear Arch Mods?
Posted 20 May 2008 - 08:29 AM
It will be on 10x6's if that's any help.
Just wondering if I should tub them while I'm working on the shell to save me having to do it later.
Posted 20 May 2008 - 08:53 AM
Also need to use short dampers.
Posted 20 May 2008 - 11:14 AM
Is an inch enough so that you don't ever catch the arch? I have nightmares about that happening, bent pannels, mangled tyres *shudder*.Think mines lowered at the back by the best part of 2" and have not needed to tub the arches... but that's in reference to where the suspension started... basically I have about an Inch gap around the tyre at the top when the car's standing level..
Don't suppose you have a picture of the bum end of your car so I can see how far off the floor the rear valance/sills are?
Posted 20 May 2008 - 12:57 PM
as your still working on your shell i would definitly do them, at that stage its not a lot of extra work.
Posted 20 May 2008 - 04:45 PM
It's just I didn't want to do it unless completely necessary as I want the shell to remain as unmodified as possible.it depends on what you carry, on my old mini (12s) with two in the back the tyres would rub the arch (its not catastrophic, just wears the paint off ), with modded rear arch the exhaust can be a limiting factor, my exhausts all take a bit of a pasting.
I'm never having anyone in the back, it's a two seater as far as I'm concerned.
Think I'll give it a miss, you seem to be able to get plenty low without tubbing and since I live in a speed bump infested area they are probably going to be the limiting factor.
Thanks guys.
Posted 20 May 2008 - 06:27 PM
if you run with people just in the front you could go a little lower
Posted 21 May 2008 - 06:22 AM
It's difficult translating a 2 finger gap to just how low the rear (valance, etc.) of the car would be, do you have any pictures from the rear with a 2 finger gap Bungle?my suspension is set very hard but i have to run with 2 fingers gap if i have people in the back
Posted 21 May 2008 - 06:47 AM
Posted 21 May 2008 - 10:08 AM
Thanks chaps!
Posted 21 May 2008 - 10:19 AM
[attachment=58568:Image013.jpg]
Posted 21 May 2008 - 11:51 AM
Yeah that's nicely low, I'll pass on the rear arch mods then .Actually think I lied, probably nearer 1.5" than 1"
Thanks again guys.
