Hi im planning to replace PANEL A POST/DOOR STEP REPAIR R/H WIND UP WINDOW TYPE DOORS this
http://www.minispare....aspx?pid=34137
Currently the mini is on a spit( so weight is supported by pole through center speedo hole and hole in the back seat. Is it necessary to support the rest of the door frame with e.g a cross made out of box section? ( One bit to the top of the door frame then to car cross member then, one to each side of the door frame) Thanks.
Bracing Shell
ad53ggz
, May 21 2008 02:41 PM
1 reply to this topic
