Heloooo!
my doorstep has had it basically, but whats the thing called behind it? i think its the inner sill but im just checking
piccy (you can see the state its in) -
Behind The Doorstep?
Down&Out
, May 21 2008 05:56 PM
5 replies to this topic
Posted 21 May 2008 - 05:56 PM
Posted 21 May 2008 - 06:25 PM
Yes, that was your inner sill.
Posted 21 May 2008 - 06:29 PM
thanks it was ruined as well...
Posted 22 May 2008 - 06:36 AM
Your inner sill is pretty much missing there!
I'd say you probably need new inner sill, new outer sill and patches to the crossmember and floor pan.
I'm sure someone else can give you better details though .
Good luck, you're alot braver than I am!
Posted 22 May 2008 - 06:48 AM
Yup you need new outer sill, the narrow type, inner sill or just make up a section from a sheet of steel, and you'll need to patch up the cross member or buy a repair section if they're available.
Posted 22 May 2008 - 04:22 PM
yup ill be doing lots of patching i have gone over the outer sill and its faily solid apart from that hole so i may just patch and waxoyl it
