Wheres All The Revs Gone?!
Posted 21 May 2008 - 10:00 PM
cheers
Posted 22 May 2008 - 10:01 AM
wahooooooooo, the car went straight through the m.o.t. IM ON THE ROAD!!! thing is i seem to be gettng the same problem as d.d had on his mini. I think we hav the same engine and problem but its unclear what solved his fault when i read through his build. At around 7/8000 rpm the engine struggles and i cant seem to get and more revs under load. Was it a re-jet that fixed the problem?
cheers
It needs to properly jetted ideally on a rolling road, even small changes effect the fueling on the carb R1
David
Posted 22 May 2008 - 01:48 PM
They have just done a Reliant kitten with a z cars frame in it fitted with a kawasaki zx10 engine on carbs so they really know there stuff. Only 5 mins from my house.
Posted 22 May 2008 - 06:31 PM
Posted 22 May 2008 - 08:17 PM
or get a dynojet kit
in no way am i saying this is better than a dyno set up but it should allow the engine to rev out in relative saftey
Posted 22 May 2008 - 09:03 PM
if you fit the non std exhaust and a non std air box it effects the amount of vacumn that the engine pulls and it gets less fuel
a dyno jet kit will sort it out and a dyno session to check correct fuelling
a simple test of this is to cover up your air filter with an old shopping carrier bag wrapped round it and just leave a 50 mm size hole for air to get through if this makes it rev out then you need bigger jets and different profile needles
chris
PS we are getting our own dyno fitted first week in june so can sort all this sort of stuff out for our customers from then onwards
Posted 22 May 2008 - 09:27 PM
Edited by dean_chad, 22 May 2008 - 09:34 PM.
Posted 22 May 2008 - 09:40 PM
David
Posted 22 May 2008 - 09:43 PM
Edited by dean_chad, 22 May 2008 - 10:09 PM.
Posted 11 December 2009 - 12:48 PM
PT
Posted 17 December 2009 - 07:14 PM
ive got half a dozen kits in stock normally £100 plus vat
you can have a kit for £50 delivered inc vat
chris
