Mini Coil Overs
20 replies to this topic
#1 richardhubb
richardhubb
  • 64 posts
Posted 22 May 2008 - 10:07 AM
im thinking up up gradeing my suspension to some coilovers all round
the ones from mini spares for lowered cars ive heard are the best i just wondered if i would need to modify my subrame front or back or the arches?
#2 [email protected]
[email protected]
    Minispares
  • Minispares
  • 3,229 posts
  • Name: Simon Jackson
Posted 22 May 2008 - 11:23 AM
They are designed to fit with the minimal of mods. A bracket set is supplied to mount the fronts, and the rear shocks have offset pins to avoid modding the rear arches
#3 richardhubb
richardhubb
  • 64 posts
Posted 22 May 2008 - 11:40 AM
thats brilliant i did think about the rears rubbing after i posted but if there supplied with offset pins jobs a gooden.
ive read some threads and people talk about didfferent weigth springs do i need to specify what i need as i have no idea?
#4 [email protected]
[email protected]
    Minispares
  • Minispares
  • 3,229 posts
Posted 22 May 2008 - 11:53 AM
No, the kits come with everything to convert a standard road going car with appropriate poundage
#5 t@z
t@z
  • 1,712 posts
  • Local Club: www.turbominis.co.uk
Posted 22 May 2008 - 12:25 PM
the lowered coil kits aren't forgiving and can give a rough ride as well as damper issues and brackets hitting the subframe if you lower them to much......well thats what i expereicnced and my mate is currently havign issues with.
#6 richardhubb
richardhubb
  • 64 posts
Posted 22 May 2008 - 02:56 PM
well what would you sujest as all i wont to do is have my wheels snugly fit im my miglia arches
would standard height ajustable go low enough?
#7 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 22 May 2008 - 03:08 PM
I would also be considering strengthening the shock mounts in the rear arches (and possibly the front)... they are not originally designed to take the sprung weight of the vehicle..
#8 t@z
t@z
  • 1,712 posts
Posted 22 May 2008 - 03:24 PM
even the lower ones are low enough for it to be snug like you describe as i think you'll need new springs and turn the shocks to super hard as its the distance between the bracket and the subframe thats your limit. but it would make for one painful ride on a road car even mine before i sold it was back breaking lol
#9 richardhubb
richardhubb
  • 64 posts
Posted 22 May 2008 - 03:49 PM
well i would like the top of the wheel to sit just below the bottom of the arches.
if i was to get coilovers would it be best to get lowerd version and wind them up or standard and wind them down?
from what people have said about coil overs they dont sound to good
i would like a smoother ride were possible, are coil overs a really ruff ride
so would just ajustable dampers do or will they rub on the arch?
#10 t@z
t@z
  • 1,712 posts
Posted 22 May 2008 - 03:59 PM
as i said i got the lowered version and didn't think they were that low to be honest but my mate has them as has to keep winding them up as the brackets keep banging on the subframe and the wheels rubbing.
they can work i think but honestly they aren't comfy lol
i think some people get used cones lower it with high lows and set the dampers to solid. but i dont think a comfy ride comes with a low car....
Edited by t@z, 22 May 2008 - 04:00 PM.
#11 supermotolee
supermotolee
  • 1,120 posts
Posted 22 May 2008 - 06:02 PM
the problems i'm having is if you run the car on its lowest settings on the coilovers (not that low by the way) the brackets supplied hit the subframe i modified the brackets now the actual coil springs hit the inner wing brackets, if your not gonna go all that low then the coilovers are very comfy actually if you dont wind the dampers up hard... this is the spax minispares kit i've not seen the gaz ones fitted...
if you want to go low you have to run them ard so stuff doesnt rub i wouldnt sugest getting the normal ride height ones as the lowered arnt all that low.
i could run my car lower on old cones hi lows and spax dampers...
#12 JR.
JR.
  • 85 posts
Posted 23 May 2008 - 11:31 PM
After buying my Mini I've just managed to get time to take the wheels off and check to see what I have on the suspension as its its very low. Its got Spax coilovers at the front (looks like Hi-lo's have been removed) and Avo's at the back with Hi-lo's. Every small bump in the road feels like a 6" pothole I've just driven over and feels like something is bottoming out.
I might have a look at either raising the rear adjusting the hi-lo's or fitting shorter or normal length shocks, but at the front there is no hi-lo's so may replace the coilovers and fit hi-lo's with short/normal shocks. Any advice appreciated
#13 JR.
JR.
  • 85 posts
Posted 30 May 2008 - 08:31 PM
Hmm not much feedback, maybe I'll post some pics up tomorrow, but meantime if someone has fitted coilovers to the front of my Mini (and yes the bracket hits the subframe) would there be any reason to remove the Hi-lo's from the front as well.?
I only ask because the Coilovers provide Rebound and damping and I cant see how you would adjust height.
#14 steveobennet
steveobennet
  • 944 posts
  • Local Club: stu's turbo club
Posted 30 May 2008 - 11:31 PM
for the front coilovers, if you want to go really low then you need to fabricate a new lower bracket.
original
mine
jr - i take it you have coilovers up front and doughnuts at the rear? you can try backing off the stiffness of the shocks and see if that helps. the coilover ride height is set by the spring. its sits on a adjustable platform the screws up and down.
if you are running both doughnuts and coilover on the front or rear someone must have had the wrong idea. if you want to run coilover you remove the original mini suspension i.e. hilos, doughnuts, knuckles.
#15 JR.
JR.
  • 85 posts
Posted 31 May 2008 - 08:04 PM
Steve thanks for the reply.
Yes I have Coilovers up front and doughnuts at the back with hi-lo's
It looks like part of the subframe has been cut away is this normal?
Mini spares doest mention that Coilovers does replace the Rubber doughnuts
so I guess my set up is correct but need to investigate why bracket is hitting the
subframe.
Edited by JR., 31 May 2008 - 08:06 PM.
